front right turn signal - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 9 (permalink) Old 05-20-2004, 11:31 AM Thread Starter
ok guys i picked up ma 2004 lapis blue mazda 6s 5speed last monday...i friggin love the car~!!.....got about 730 miles on in right now but i noticed that somes times my right turn signal in the head light assembly doesnt work at all and sometimes it does......could it be a loose wire?....i checked the wire seemes pretty tight ......some help please....thanx a lot
sukhyunx012 is offline
post #2 of 9 (permalink) Old 05-21-2004, 09:31 AM
Replying to Topic 'front right turn signal'
Move to Texas and quit using your turn signals. Problem solved. :D
Seriously, if the problem is isolated to a single front lamp, the odds are it is a loose connection. If the problem affects the front and back on that side, add a suspect turn signal switch to your list. If it problem affects both sides of the car, add a suspect relay to the list of possible causes.
Does it act up frequently enough to reproduce it at the dealership? If so, save yourself the heartache and let them troubleshoot it for you.
Monk is offline
post #3 of 9 (permalink) Old 05-22-2004, 03:55 PM
I had the same problem except it was the left front. One of the sales managers fiddled with the connection and it started working fine. that was abot 2500 miles ago and it just started doing it again
linzTNstlgrey is offline
post #4 of 9 (permalink) Old 05-22-2004, 11:14 PM
I just had this problem last week. I searched the forums and it seems to be happening to several people. I haven't taken my car in yet, but here is the link to the forum which states that mazda has a particular solution:
http://www.mazda6club.com/forums/read.php?TID=11435
stix16 is offline
post #5 of 9 (permalink) Old 06-04-2004, 08:28 AM
04WhiteSix's Avatar
Reading Topic: front right turn signal
what you do is take out the turn signal (turn hard! until it clicks then pull it out) take a look at the silver contacts in the middle of the unit and bend them out a bit then put back in and perfecto!
2004 Mazda 6S MTX
2002 Yamaha Warrior
04WhiteSix is offline
post #6 of 9 (permalink) Old 06-04-2004, 02:23 PM
mbrogz3000's Avatar
Originally posted by 04WhiteSix
* * * * * * what you do is take out the turn signal (turn hard! until it clicks then pull it out) *take a look at the silver contacts in the middle of the unit and bend them out a bit then put back in and perfecto!
yeah, do this AND rub down the contact with rubbing alcohol...also look for fingerprints...mine had a fingerprint from the factory
mbrogz3000 is offline
post #7 of 9 (permalink) Old 06-10-2004, 03:07 PM
To emphasize this point, same happened to me before I even pulled out of the dealership. According to their mazda tech, they desined this new gig with the bulb attached to a plastic shaft for easier access. You won't get a ground signal unless you turn it clockwise untill it click. My fix took seconds.
jpmm is offline
post #8 of 9 (permalink) Old 06-14-2004, 07:34 AM Thread Starter
thanx alot for ur help guys....problem fixed....=)
post #9 of 9 (permalink) Old 07-06-2016, 11:57 AM
I know this is an old thread but I'm hoping that someone is still paying attention. I've got a 2004 Mazda 6 sedan that would occasionally have issues with the left turn signal not blinking. When pushing down the left turn signal switch, the signals would stay off. I could have it engage by manually turning the switch up and down, but in the last few days even that doesn't work. Here's what I've done:
1) Changed front and back turn signal bulbs.
2) Checked the front turn signal socket, pulling out the silver contacts to ensure they're making contact.
3) Tried the right front turn signal socket in place of the left socket.
4) Checked the fuse.
No luck with any of these steps. Any ideas?
FrostyOfTheNorth is offline
