K&N filters - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Go Back   Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum > Mazda6 (Atenza) > Consumer Reviews
New User? Register
Old 05-02-2003, 01:52 PM   #1 (permalink)
Canada_Rico's Avatar
Send a message via MSN to Canada_Rico
Default K&N filters
[glow tcolor=red, fcolor=black, size=2, strength=1]Does anyone know if they have K&N Filters for the 6 yet. I live in Canada, but I have not seen them yet.[/glow]
Canada_Rico is offline   Reply With Quote
Old 05-02-2003, 02:28 PM   #2 (permalink)
Absolut's Avatar
Send a message via AIM to Absolut Send a message via MSN to Absolut
Default Reading Topic: K&N filters
Yeah they do. Check the K&N website and you will get a part number. They have one for both the i and s models.
http://www.knfilterchargers.com/search/appsearch.aspx
Here's your part numbers... YOu should be able to take these numbers to any K&N dealer and pick it up or have them order it.
6i: 33-2278
6s: 33-2279
Eh.. I was bored and figured I would do it myself :)
Storm Reports Map: http://www.stormreportmap.com
Absolut is offline   Reply With Quote
Old 05-02-2003, 02:41 PM   #3 (permalink)
Thanks a lot. by the way, do you use synthetic or standard oil for your M6.
Old 05-02-2003, 03:41 PM   #4 (permalink)
Absolut's Avatar
I use standard... Mazda says there is no use for using synthetic.
Old 05-02-2003, 04:24 PM   #5 (permalink)
Just watch out. My boyfriend had one installed on his Hyundai Tiburon and it caused some problems. When it got cold and wet over the winter, some moister got into one of the sensors and the car didn’t like it. He had it removed and now it’s running fine. He’s planning on installing it again, but just leaving it in for the summer months.
Lady Blue6 is offline   Reply With Quote
Old 05-02-2003, 07:30 PM   #6 (permalink)
Default Replying to Topic 'K&N filters'
QUOTE
Originally posted by Absolut
* * * * * * I use standard... Mazda says there is no use for using synthetic.[/b]
That is not true. Mazda does not "recommend" synthetics as a matter of policy due to the fact that it causes problems with the rotary engines--certain rotor seals are suspected of failing under certain condidtions using certain synthetic formulas. I can assure you that synthetics offer many advantages in piston based enignes over petrolium based oil.
Kristoff is offline   Reply With Quote
