2003 6i ATX: Driver window stopped working - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 11 (permalink) Old 04-24-2013, 07:54 PM Thread Starter
kikboxr1's Avatar
I apologize if there is an existing thread about this, but I haven't mastered the search function of the Autoguide app.
Our trusty 03 6i's driver window won't roll up or down. The other windows function via the driver switches. Do I need a whole new unit or is it just the one switch that went bad?
2003 Mazda 6i ATX
kikboxr1 is offline
post #2 of 11 (permalink) Old 04-24-2013, 09:01 PM
RayM6's Avatar
Quoted: 17 Post(s)
try this.
1. Disconnect battery
2. Reconnect battery
3. turn on car and hold the window switch up until you hear a clicking sound. Thats what I did on my 07.
RayM6 is offline
post #3 of 11 (permalink) Old 04-24-2013, 09:02 PM
RayM6's Avatar
Quoted: 17 Post(s)
It should click twice
RayM6 is offline
post #4 of 11 (permalink) Old 04-24-2013, 09:06 PM
RayM6's Avatar
Quoted: 17 Post(s)
let me know if it works
2007 Glacier Silver Mazda 6i ATX
RayM6 is offline
post #5 of 11 (permalink) Old 04-24-2013, 09:43 PM Thread Starter
kikboxr1's Avatar
Thanks for the recommendation, but nope it didn't work. I should have prefaced my message with the fact that I did try the reset procedure in the manual.
It's only the driver window that stopped working. Which sucks because then we look like hoods at drive thrus.
2003 Mazda 6i ATX
kikboxr1 is offline
post #6 of 11 (permalink) Old 04-24-2013, 09:55 PM
RayM6's Avatar
Quoted: 17 Post(s)
damn
RayM6 is offline
post #7 of 11 (permalink) Old 04-27-2013, 08:35 PM Thread Starter
kikboxr1's Avatar
Bump...
No one had a similar experience?
2003 Mazda 6i ATX
kikboxr1 is offline
post #8 of 11 (permalink) Old 04-27-2013, 08:38 PM
Drizzoh's Avatar
Quoted: 335 Post(s)
Groaned at 8 Times in 7 Posts
Send a message via AIM to Drizzoh Send a message via MSN to Drizzoh Send a message via Yahoo to Drizzoh
It's probably failed.. You can swap out the motor with the passenger rear door (they have flip flop compatibility) or replace the track/motor as per my DIY: DIY: Window Motor & Regulator Replacement
Andrew |
Drizzoh is offline
post #9 of 11 (permalink) Old 05-01-2013, 01:03 AM Thread Starter
kikboxr1's Avatar
If the motor failed, I could test it by jumping a couple contacts on the plug going into the switch, no? If I jumped the driver down wire and it didn't go down, then I could assume the motor is bad. Anyone know how I might jump it to bypass the switch?
2003 Mazda 6i ATX
kikboxr1 is offline
post #10 of 11 (permalink) Old 06-01-2013, 12:05 AM Thread Starter
kikboxr1's Avatar
I picked up a master switch off eBay for $30. I guess out of laziness, I hadn't tested the current at the motor before. Turns out the sucker is getting voltage at the motor, so I'm guessing it is dead. I'll follow the DIY and swap out the motor tomorrow. Thanks Drizzoh.
2003 Mazda 6i ATX
kikboxr1 is offline
