Metra Install Kit Display Problem - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 30 (permalink) Old 07-10-2012, 07:34 PM Thread Starter
Hi guys,
Installing an aftermarket head unit in my 2005 6 (non-Bose) system. I'm using the Metra 99-7503 kit and a Pioneer DEH-2950MP unit. All the speakers, air con and climate control work, but the clock/temp display is blank. It's backlit and flashes when initially turned on, but the information doesn't come up.
Anyone else had this problem?
Cheers,
Nick
Janesy is offline
post #2 of 30 (permalink) Old 07-10-2012, 07:40 PM
fallenambience's Avatar
Quoted: 444 Post(s)
Are the pins aligned correctly? I would have assumed you didn't plug it in but if it flashing it must be getting power.
l
l
l
Have I helped you or supplied you with Information? Thank me by donating to The New England Mazda6 Auto Club
fallenambience is offline
post #3 of 30 (permalink) Old 07-10-2012, 08:27 PM
Riki desu's Avatar
Quoted: 93 Post(s)
I remember reading some threads that had the same problem as you. The thing in common was those people were non US. Don't know if they fixed the problem though. I would search through the forum, if it's not just a loose connection.
2004 Mazda6 Sport GT,Onyx Black
Mods: Injen SP6072P CAI, 3.7l TB, 3/4" IM spacer, Mazdaspeed 3.0L v6 cat back, EGR Optimization/Re-Route, Transmission Cooler + Inline filter, TB coolant bypass/T replacements, 35 watt 5K HID Low Beams and Fogs
2011 Infiniti G37S Coupe,Obsidian Black, MTX
Mods: Complete Aero Body, Midnight Grill, Lip Spoiler, Tanabe Springs, RJM Clutch Pedal, Stillen Gen3 CAI
Riki desu is offline
post #4 of 30 (permalink) Old 10-25-2012, 10:09 AM
hey guys, i am new in this forum and wondering if i can get help in her .
i have the same problem as the guy above , bought a new double din fascia for my 2004 mazda 6 (australian) and install it by professional however he couldn't find out how to make the upper unit work,the display tunes on when i switch the light on but no display . the a/c working fine as well as the dvd unit .
i tried to contact the seller but no respond ,
this is the fascia
Mazda 6 Radio Stereo Car Install Double DIN Mount Navigation Bezel Kit Harness | eBay
Mosh is offline
post #5 of 30 (permalink) Old 10-25-2012, 02:54 PM
6xer's Avatar
Quoted: 68 Post(s)
if you search double din you would see my thread.
6 Double Din
6xer is offline
post #6 of 30 (permalink) Old 10-26-2012, 01:56 AM
ctmazda's Avatar
Quoted: 291 Post(s)
Groaned at 5 Times in 5 Posts
The link that he posted is the same one that you have.
Sent from my iPhone using Autoguide
2004 Mazda 6 Sport V6 MTX-Steel Grey
MSDS Headers/Ported Intake Manifolds + 1/2" Spacer/Injen CAI/3.7L OTB/TGNY TB Spacer/Magnaflow CBE/AWR 88 Mounts/Rotora H2 Ceramic Brakes//CF Evo Hood,Grill,Eyelids,Window Visors,Mirror Covers/CAR-LED Tails/35W 5000k HIDs/55W 6000k Integrated Fogs/LED Fogs/1000w Xplōd Amp/Two 800w 12" Xplōd Subs/15% Tints/18x8.5 +50 Kazera "CF" Rims/Hankook Ventus Evo 245/40/18
Future Mods:Powermod Tuner/Custom DoubleDin/BC Coils
ctmazda is offline
post #7 of 30 (permalink) Old 10-26-2012, 08:14 PM
6xer's Avatar
Quoted: 68 Post(s)
I know that... Just showed him it just because incase he didn't have reference pics.
And if I remember right people that didn't have U.S. models even the metra kit had problems. I don't remember reading if anybody got it working right on a non-U.S. model 6
6xer is offline
post #8 of 30 (permalink) Old 11-27-2012, 02:23 PM
Quoted: 4 Post(s)
Same problem
My center display didn't work either until I started to play around with the 9 pins in the center of the circuit board. Just touch a couple of the pins together with a flathead screw driver and you should see the display show something. I haven't figured out how to get it to work, but if you touch the correct two pins together it should start working. The only thing I can't figure out is how to adjust the clock. I hold down the clock button and nothing happens. The set button and the dimmer button do the same thing and adjust the brightness. Trying to figure it out.
jcf6288 is offline
post #9 of 30 (permalink) Old 12-02-2012, 09:07 AM
I have read some things about using the factory radio oem connector? I've tried this, but I still have the same issue.. Like yours, mine flashes and then turns off - I have noticed its (very) lightly back-lit, so maybe it's just not getting enough power?
I had to move the amp on pin on the metra harness, as it didn't match the oem connector.. Makes me wonder which other pins weren't mapped correctly, at the factory...
Anyone have a solution for this? It's driving me nuts. :/
I should mention, I'm in Australia, driving an '03 6 GG series 1 luxury, using a pioneer DEH-X6550BT Headunit.
Xtrasimplicity is offline
post #10 of 30 (permalink) Old 12-03-2012, 08:01 AM
hi all, I'm glad I found this thread. I am in the UK and bought the ebay kit mentioned above. I am having the same issues mentioned here. The head unit works ok but the display is just back lit and blank. It briefly displays some random characters when being powered on then stays blank. I am not sure if the 3 HVAC buttons are working correctly as the LED's are behaving quite randomly coming on and off occasionally.
jcf6288 - Which 2 of the 9 Pins did you touch together to get the display working? I cant get any change on the display when trying this. Also what country is your car?
otl-Mazda6 is offline
