RCA Cable length? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Go Back   Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum > Visual / Audio > Mazda 6 1st Generation (2002-2008) > In Car Electronics
New User? Register
Old 05-04-2012, 10:37 PM   #1 (permalink)
Wim
Wim's Avatar
Quoted: 132 Post(s)
Default RCA Cable length?
For those of you who have wired amps in the trunk, what have you found when running cables there? I'm about to order some RCA cables and would like to get as short as possible, avoiding the dreaded loop while still leaving a bit of slack to play with on either end.
If all else fails, you weren't driving a Mazda6
Handling: H&R lowering springs - Tokico Blues - OPC ball joints - Whiteline Rear Sway Bar - Adjustable Endlinks - DBA 4000 Series rotors w/ Hawk HPS Pads Front and rear
Stereo: Metra single DIN plate - Kenwood Excelon x950 Headunit - Kenwood Excelon shallow mount subwoofers - Boston Acoustics SR60 separates up front - Rockford Fosgate T500-1bdCP, Rockford Fosgate T400-4
Prettified: Speed6 rims powdercoated black - Tinted windows
Wim is online now   Reply With Quote
Old 05-04-2012, 11:17 PM   #2 (permalink)
Riki desu's Avatar
Quoted: 20 Post(s)
Idk. My RCA's are 16ft long or something. Maybe run a wire back there, cut it, and figure out what the length is.
2004 Mazda6 Sport GT
Onyx Black
Currently
Mods: Injen SP6072P CAI, EGR Optimization/Re-Route, Transmission Cooler + Inline filter, TB coolant bypass/T replacements,
35 watt 5K HID's in Low Beams and integrated Fogs, LED DRL lights in stock position
Int. Mods: Aftermarket Audio system, LED Interior lights
Ext. Mods: Brake Light Mod, Door Guards removed, Smoked License Plate Cover, O-series Stubby Antenna, JDM Atenza Wind Visors, 35% Tint
Riki desu is offline   Reply With Quote
The Following User Says Thank You to Riki desu For This Useful Post:
Wim (05-04-2012)
Old 05-04-2012, 11:50 PM   #3 (permalink)
Wim
Wim's Avatar
Quoted: 132 Post(s)
Riki Riki Riki. The whole POINT of having forums is so that I don't have to a) think for myself or b) do any *gasp* manual labor.
I guess I'll be doing that after all if no one recalls
Old 05-05-2012, 12:04 AM   #4 (permalink)
Riki desu's Avatar
Quoted: 20 Post(s)
Lol. Good point. I'd say somewhere around 10-12ft depending on if you run it through the center console and under the carpet or along the side of the car and depends on where your amp rack is. I have a lot of slack so I know 16 is too long.
Oh and remember about the little holes, one on each side of the car behind the cushions next to the back seats. Idk if the speed6 has them but I'd assume it does. They are perfect to run wire through so it's hidden, if you're running it along the sides.
Onyx Black
Currently
Old 05-05-2012, 02:50 AM   #5 (permalink)
Project_dog's Avatar
Quoted: 8 Post(s)
What holes?
Sent from my Autoguide iPhone app
***RIP mazda 6i RIP***
Project_dog is offline   Reply With Quote
Old 05-05-2012, 06:17 AM   #6 (permalink)
Wim
Wim's Avatar
Quoted: 132 Post(s)
I'm with project dog on this one. What holes? I plan on pulling out the seats and lifting the carpets in order to lay down a bunch of the Dynamat. So I should have easy access to these holes!
Sent from my DROID RAZR using AutoGuide.Com Free App
Old 05-05-2012, 09:48 AM   #7 (permalink)
Riki desu's Avatar
Quoted: 20 Post(s)
Oh... It's a secret...
Onyx Black
Currently
Old 05-05-2012, 11:09 AM   #8 (permalink)
MonoxideChild's Avatar
Groans: 65
Groaned at 23 Times in 19 Posts
iTrader: 2 reviews
there are like 4-5 inch round holes on each side of the back seat. you really cant miss them there that huge once you pull the side parts of your back seats out.
MonoxideChild is offline   Reply With Quote
Old 05-05-2012, 11:19 AM   #9 (permalink)
Riki desu's Avatar
Quoted: 20 Post(s)
NOOO. Why did you tell them...
Onyx Black
Currently
Old 05-05-2012, 11:22 AM   #10 (permalink)
Riki desu's Avatar
Quoted: 20 Post(s)
Ok. I have pictures.
Its the same on each side.
Fold the seat down and un clip the cushion, you'll see the hole.
It's right underneat the clip for each cushion. I have mine closed up, the hole is under the deadener, you can see my RCA's going through it.
Big box
Onyx Black
Currently
The Following User Says NO Thank You to Riki desu For This Un-useful Post:
Outlook (10-22-2012)
