do any know what is the color code on the speaker wires from the bose head unit ii want to know which ones are positive and negative
I'll list the non-Bose wiring. If you need the Bose setup, let me know.
LH Front Door = White/Black+ Gray/Black- RH Front Door = White/Red+ Gray/Red- LH Tweeter = White/Red+ Gray/Red- RH Tweeter = White/Black+ Gray/Black- LH Rear Door = White/Violet+ Gray/White- RH Rear Door = White+ Gray- ~Mike Example: White/Gray = White with Gray stripe.
2009 Mazda 6 GT in Sangria Red. |
Sorry about that, I guess I didn't see the Bose thread title the first time.Your posts asks for the speaker wires from the head unit...but the speakers connect directly to the Bose amplifier so I will supply those. The wires from the head unit to the amp are just data wires and aren't labelled in the wiring diagram except for their colors. LH Front Door = White/Black+ Gray/Black- RH Front Door = White/Red+ Gray/Red- LH Tweeter = White/Red+ Gray/Red- RH Tweeter = White/Black+ Gray/Black- (The tweeters are wired in parallel with the door speakers. Yes, the wires switch color after the door speakers.) Center Front = White/Red+ Gray/Red- LH Rear Door = White/Violet+ Gray/White- RH Rear Door = White+ Gray- LH Rear Shelf = White/Red+ White/Blue- RH Rear Shelf = White/Blue+ Gray/Red- (The rear shelf speakers are wired in series, the White/Blue wire connecting them.) Rear Center = White/Black+ Gray/Black- ~Mike
do you know where the amp is located in the also if you dont mind can you give me all the color code on thw wires in the back of the head unit what their for?
The wiring book shows the amp to the right of the glove compartment behind the bluetooth module.
Sorry, the spacing messed up on the first connector. It's the only odd one that's not 2 rows. [Back of NAV unit.] 1X 1V 1U 1S 1F 1D 1C 1A 1W 1T 1P 1N 1L 1J 1H 1B 1R 1Q 1O 1M 1K 1I 1G 1E 1A Front door speaker LH(+) W/B 1B B= O/B 1C Front door speaker LH (-) GY/B 1D Front door speaker RH (+) W/R 1E TNS (+) O/B 1F Front door speaker RH (-) GY/R 1G Illumination (-) BR/Y 1H ~ 1I Vehicle Speed Signal W 1J AMP control W/G 1K Parking brake signal B/O 1L ~ 1M ~ 1N Audio control switch 1 W/B 1O CAN (+) GY/R 1P Audio control switch 2 BR/Y 1Q CAN (-) L/R 1R ACC L/B 1S Rear door speaker LH (+) W/V 1T Audio Pilot GY/R 1U Rear door speaker LH (-) GY/W 1V Rear door speaker RH (+) W/L 1W Power Ground B 1X Rear door speaker RH (-) GY ----------- 2O 2M 2K 2I 2G 2E 2C 2A 2P 2N 2L 2J 2H 2F 2D 2B 2A Power Ground B (with HF and without Sirius) 2B TEL (+) W (with HF) 2C Input signal RH (+) W/G 2D Input signal RH (-) 2E Input signal LH (+) R/L 2F Input signal LH (-) 2G Signal Ground B/G (B/W with HF and without Sirius) 2H ~ 2I ~ 2J TEL (-) GY (with HF) 2K ~ 2L ~ 2M AUX CONT W/V (with HF and without Sirius) 2N ~ 2O ~ 2P ~ ---------- Mic Connector F E D C B A A Mic (+) B Mic (-) C ~ D GND E Mic detect F ~ ---------- [Amplifier] 1O 1M 1K 1I 1G 1E 1C 1A 1P 1N 1L 1J 1H 1F 1D 1B (This connector has an off center track on the bottom.) 1A AMP Control (SW B+) W/G 1B SPEED signal input W 1C Front door speaker input LH (-) GY/B 1D Front door speaker input LH (+) W/B 1E Front door speaker input RH (-) GY/R 1F Front door speaker input RH (+) W/R 1G Rear door speaker input LH (-) GY/W 1H Rear door speaker input LH (+) W/V 1I Rear door speaker input RH (-) GY 1J Rear door speaker input RH (+) W/L 1K ~ 1L AUDIO PILOT GY/R 1M ~ 1N ~ 1O MIC input (+) W 1P MIC input (-) GY ---------- 2O 2M 2K 2I 2G 2E 2C 2A 2P 2N 2L 2J 2H 2F 2D 2B (This connector has wings sticking up on both sides.) 2A ~ 2B Rear door speaker (LH) output (-) GY/W 2C ~ 2D Rear door speaker (LH) output (+) W/V 2E Rear speaker output (+) W/R 2F ~ 2G Rear speaker output (-) GY/R 2H ~ 2I Front center speaker output (+) W/R 2J ~ 2K Front center speaker output (-) GY/R 2L ~ 2M Rear door speaker (RH) output (+) W 2N ~ 2O Rear door speaker (RH) output (-) GY 2P ~ ---------- 3G 3E 3C 3A 3H 3F 3D 3B 3A B+ R/O 3B Power Ground B 3C Front door speaker (LH) and tweeter (LH) output (-) GY/B 3D Front door speaker (LH) and tweeter (LH) output (+) W/B 3E Front door speaker (RH) and tweeter (RH) output (-) GY/R 3F Front door speaker (RH) and tweeter (RH) output (+) W/R 3G Rear center speaker output (-) GY/B 3H Rear center speaker output (+) W/B Well, I hope this helps. Enjoy! ~Mike edit: I guess i should add a color code key: B BLACK L BLUE BR BROWN DL DARK BLUE DG DARK GREEN GY GRAY G GREEN LB LIGHT BLUE LG LIGHT GREEN O ORANGE P PINK R RED SB SKY BLUE T TAN V VIOLET W WHITE Y YELLOW
#8 (permalink) |
LH Rear Door = White/Violet+ Gray/White- RH Rear Door = White+ Gray- LH Rear Shelf = White/Red+ White/Blue- RH Rear Shelf = White/Blue+ Gray/Red- (The rear shelf speakers are wired in series, the White/Blue wire connecting them.) Rear Center = White/Black+ Gray/Black- ~Mike [/quote] HI mIKE I hope you can help me on this questions (3) 1.-i 'll install an aftermarket amplifier but i need to know how the last 4 rear speakers works because the amplifier has only 2 for rear speakers and the center i think it can work like subwoofer. 2.-how many watts maximun i can put on each bose original speaker with the new amplifier. 3.-do you know the code or part number for bose speaker wire adapter. 4.- last one i'm installing new stereo 2 din dvd gps so my problem was the antenna conector, i got an antenna adapter 40-HD10 but i need to know were the lose wire needs to be conected. sorry for many questions, your the best Mike or somebody else that wants to help me.
Richie |
#9 (permalink) |
1. Each rear door speaker, the sub, and the front center has their own set of two wires. Each front door speaker is connected in parallel with the tweeters. The two speakers in the back corners are wires in series.
2. Sorry, none of my fer materials mention the speaker wattage. 3. No. 4. When I installed the Caska NAV, I used the adapter from the original NAV and didn't connect the loose wire. My guess is that it's a turn-on wire for the antenna amplifier but without being connected, it still picked up all stations for me with the aftermarket unit. ~Mike
