Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > Visual / Audio > Mazda6 2nd Generation (2009-Present) > In Car Electronics
Old 04-04-2009, 10:13 AM   #1 (permalink)
Talking
Well i've just finished all working but need to change steering controls to get back access to the trip computer. Heres the install :
http://www.mazda6forums.co.uk/forum/index....opic=220.msg650
andythilo is offline   Reply With Quote
Old 04-14-2009, 04:48 AM   #2 (permalink)
QUOTE (AndyThilo @ Apr 4 2009, 07:13 AM)
http://www.mazda6forums.co.uk/forum/index....opic=220.msg650[/b]
Looks like a good job
Did you connect wires for speed sensor, parking brake, reverse gear ?
If you did - can you provide details of the colors of the wires and where to find them ?
- Per
pleslie is offline   Reply With Quote
Old 04-17-2009, 02:13 AM   #3 (permalink)
I'm REALLY curious on your install as I'm looking into putting the F90BT into my 09... Do you know if the facia plate you bought from the ebay store in london will fit the USDM? (maybe could you measure top/bottom so I can compare) It looks super clean and exactly how I want my install to look!!
2009 Brilliant Silver Mazda6 iSV MTX
5% Tint all the way around/2 12" AudioBahns/Rockford Fosgate T400-4/P1L-2X12/ Pioneer AVIC F90BT/ Viper Responder 250 Security
jwoidami is offline   Reply With Quote
Old 04-17-2009, 01:01 PM   #4 (permalink)
QUOTE (pleslie @ Apr 14 2009, 08:48 AM)
- Per[/b]
Hi
There is no speed sensor on the Bose equipped Mazda 6's, something to do with the Bose system, theres info about it in the PDF I linked to at the bottom of my How2, the parking brake wire is simply grounded and I havent connected the reverse wire as I have no reverse camera installed, but again it details it in the PDF.
QUOTE (JBB @ Apr 17 2009, 06:13 AM)
I'm REALLY curious on your install as I'm looking into putting the F90BT into my 09... Do you know if the facia plate you bought from the ebay store in london will fit the USDM? (maybe could you measure top/bottom so I can compare) It looks super clean and exactly how I want my install to look!![/b]
Hi, as far as I know the stereo fascias are common across all continents, i'm sure you can buy them in the US, try Crutchfield.
Old 04-23-2009, 09:19 AM   #5 (permalink)
QUOTE (AndyThilo @ Apr 17 2009, 09:01 AM)
Hi
There is no speed sensor on the Bose equipped Mazda 6's, something to do with the Bose system, theres info about it in the PDF I linked to at the bottom of my How2, the parking brake wire is simply grounded and I havent connected the reverse wire as I have no reverse camera installed, but again it details it in the PDF.[/b]
I have installed a JVC system (KW-NX7000) in my Mazda6..... I changed the top display so TripComputer is working and I changed the Steering wheel controls so I got the "Info" button..... but pressing on in doesn't change the Trip info....it just stays on the Consum/100 km setting.....
Did you get your steering wheel controls changed yet and did you get it to work ?
Everything else works like a dream
Cheers from Denmark
- Per
Old 04-24-2009, 03:52 PM   #6 (permalink)
QUOTE (pleslie @ Apr 23 2009, 02:19 PM)
Cheers from Denmark
- Per[/b]
Hi
Yes I did it today and it works brilliantly. You need to get the adaptor cable, this plugs inline with the display connector, and then a single brown wire runs to the steering column and goes inline with the connector there. The Mazda part no. you need is : GS1DV6609 (this is a Uk part no. but should be the same elsewhere).
If you have a look here you can see the display side of the adaptor :
http://farm4.static.flickr.com/3384/341184..._1a2866152c.jpg
If you need help let me know.
Cheers
Andy
Old 05-14-2009, 11:47 PM   #7 (permalink)
Just a heads up. The F series knows if your actually parked. Not only can it sense the parking brake, but there is also a built in gyro sensor and the GPS will know when your moving
2003 Mazda 6s GT MTX
Steel Grey Metallic
Magnaflow Exhaust w/o Resonator
Bosche Ballast/ECE E46 Full HID Retro
Eibach Sportlines Springs
18x8 RX8 Alloy Wheels
Alpine PDX 4.100, PDX 1.600, SPR-17S Type R Components, SPR-17C Type R co-ax, Single SWR-1242D Type R Sub
*coming soon- Pioneer AVIC-Z110BT, custom modified DOUBLE DIN kit*
Mazda 6s GT is offline   Reply With Quote
Old 05-29-2009, 09:00 AM   #8 (permalink)
QUOTE (Mazda 6s GT @ May 14 2009, 08:47 PM)
Just a heads up. The F series knows if your actually parked. Not only can it sense the parking brake, but there is also a built in gyro sensor and the GPS will know when your moving[/b]
The geniuses at Pioneer are also well aware that people don't spend $1000+ to watch videos and use the GPS when the car is in park/ebrake is on... if they did it wouldn't be so easy to bypass and/or there would be software locks on certain features. It knows, yes, but it doesn't care, and it's programmed not to care
Old 06-11-2009, 03:37 AM   #9 (permalink)
QUOTE (Mazda 6s GT @ May 15 2009, 04:47 AM)
Whether the head unit knows the car is stationary or not it makes no difference, the Nav still works 100%, in fact everything works 100%
Old 06-11-2009, 09:15 PM   #10 (permalink)
QUOTE (AndyThilo @ Jun 11 2009, 03:37 AM)
Whether the head unit knows the car is stationary or not it makes no difference, the Nav still works 100%, in fact everything works 100%[/b]
Its supposed to work. Its any viewing of other video sources, except rear view camera input, that wont work.
Steel Grey Metallic
