There have been a lot of questions regarding wiring the Metra kit lately for both Bose and non-Bose, so I figured I'd try to consolidate some information to help people with their installations.
I put together what I feel is a great resource if you are wiring up any system in a Mazda6. I've attached the PDF that I've created. Non-Bose -Uses 4 ohm speakers -Does not have an external amplifier -The Metra harness "Speaker" wires will lead directly to the speakers. If you have the Non-Bose system, wiring up your new stereo to the stock speakers and wiring is very easy, just follow the instructions that come with the Metra kit. The 4 ohm impedance of the speakers will not cause any problems with an aftermarket deck and you don't have to worry about a factory amplifier mucking things up. Bose -Uses 2 ohm speakers -Has an amplifier under the passenger seat -The Metra harness "speaker" wires actually lead to the preamp input of the amplifier. Examine the wiring harness diagrams I have attached and you'll see what I'm saying. Given this information, it's important to note: If you have the Bose system, and you hook up the speaker wires of your new head unit to the "speaker" wires in the Bose harness, you will be sending an amplified signal to the Bose amplifier's preamp input and the result will be less than stellar, actually quite crappy, sound. On the other hand, this also allows you to easily integrate an aftermarket deck using it's preamp (rather than speaker) outputs. So you can run the Bose system off of a different head unit. Research shows that the signal processing for the Bose system is actually performed in the amplifier. So the system should perform identically even if you replace the head unit. To do this, it's as easy as soldering on 4 male RCA plugs to the "speaker" wires in the Metra harness. The negative "speaker" wire should be soldered to the pole on the plug that connects to the ring. The positive "speaker" wire should be soldered to the pole on the plug that connects to the post. Once you've done this for the FR, FL, RR and LR "speaker" wires, all you have to do is plug in your front and rear RCA jacks from your head unit and all should work well. One thing to note on this sort of set up. You will want to be very judicious with the volume control until you figure out how the system is going to perform. Some aftermarket head units have very strong preamp signals that could easily overdrive the Bose amp if care is not taken. If it turns out that your system is reaching full volume at low settings on the volume control, the preamp output will probably have to be padded. Another note on the Bose system is that there is no way to run the stock Bose speakers off of an aftermarket head unit without using the Bose amp. Firstly you'd have to bypass the Bose amp all together and I'm pretty sure there is no harness made to do this like there is for other cars. Secondly, the low impedance (2 ohms) of the speakers would either have your head unit going into protection, or fry the amplifier section all together. Both of which are not good situations. You can use an aftermarket amplifier to drive the Bose speakers since every amp I can think of is 2 ohm stable. However, given the signal processing built into the Bose amp, you probably won't be very satisfied with the sound. If you want to use the aftermarket Deck to run some aftermarket door speakers, you're going to have to either make up an amplifier bypass harness using the diagrams I made, or run new wiring into the doors. Kinda a pain in the ass, but until there is an amplifier bypass harness made, it is your only choice. I think that covers the basics of using the Metra kit with both systems. Let me know if anyone has questions or corrections.
Performance: CP-E Engine Mount - Autovation Racing Pedals - Single 2.5" exhaust - Magnaflow Mufler/Resonator - Graphite Konig Troubles with Toyo Proxes 4 (Summer) RX-8 16s with Hankook Z212 (race) stock 16s (winter) - Mazdaspeed Short Throw Shifter - Mazdaspeed6 shocks and springs - Racing Beat Rear Swaybar and endlinks - CPE MAFCi Exterior: ATH lip Kit - Badgeless Grill - Stock lower fog lights - Euro tail lights tinted red - Side marker tinted overlays Audio: Alpine CDA9887/Ipod, molded metra dashkit - Rockford Fosgate Power T3002: Dayton RSS315HO-4 (changes sometimes)- Rockford Fosgate Power T4004: Dayton RS180-4 in doors and Dayton RS-28A in kickpanels, actively crossed - Kicker Hyperflex 1/0 wiring. In The Basement: Tinted headlight bezels - DIY LED Halos - rear bumper lip </span>[/i] Currently the engine is out due to Pre-Cat failure on the front bank. Rebuilding with 2004 Sable shortblock, Ebay headers, Fidanza flywheel, stock clutch, AWR engine mounts, Aeroforce Interceptor, Glowshift Oil Pressure. <span style="color:#FF0000">Rebuilt frankensablemazda motor is in, AND IT RUNS |
Makes me happier and happier every day that I didn't waste money on bose.
Would be a good topic to pin.
Reliable Web Hosting | Clustered Web Hosting | ASP Hosting | <a href="http://www.reliablesite.net/v3/reseller.asp" target="_blank">Reseller Hosting | Dedicated Servers </a></span> 2004 Lapis Blue Mazda6 S 5 Speed Auto - RIP 2005 Redfire Metallic Mazda6 S 6 Speed Auto 2004 Blue BMW 530i 6 Speed Auto 2004 Jet Black BMW Z4 3.0i 6 Speed Stick 1999 Brilliant Black Miata 5 Speed Stick - <span style="color:red">Sold! |
Glad I didnt get the Bose also, i wanted to change all speakers and everything anyway. But this is what a forum is suppose to be about. People helping each other out with useful information instead of useless attacks. Great write up, and I know alot of people are going to enjoy it.
04 Onyx Black Hatch 6i 2 MA Audio 1200XLS 600wrms/1200wmax dual 4ohm 1 MA Audio HK-302SX 1400wrms @ 1ohm 1 MA Audio 1 Farad Digital Cap 1 Optima Yellow Top Battery |
Very intuitive. I just have one question. You mentioned that the signal processing is built into the amp. If I were to replace the amp and speakers without replacing the deck, the sound wouln't be very satisfactory?
#5 (permalink) | |
#8 (permalink) |
Good information and since you seem to know a lot about the 6 audio, would it be possible to put a 6 cd changer into a normal non-bose 6 radio?
2004 6i ATX Lapis Blue <strike>CP-E CAI,</strike> Mazdaspeed Springs, Magnaflow Exhaust, <strike>Hiboost Turbo</strike>, F5 Fujita CAI, VIS EVO hood, New car soon? MySpace Page
#9 (permalink) | |
#10 (permalink) |
Great write up Dave and thanks for all your help when I was installing my HU. I am actually going to be trying to install a 6 disc in my friends non bose...will let you guyz no how that turns out.
2005 Winning Blue RX-8 - 6 spd - Grand Touring - Rear Wing Spoiler - MazdaSpeed Dual Sport Exhaust - SR Motorsports High Flow Cat - AEM Cold Air Intake - Agency Power Underdrive Crank Pulley - ACT ProLite Flywheel - ACT Street/Strip Clutch - Axial Flow Short Shifter - TEIN Flex Coilovers with Tein EDFC - Racing Beat Front/Rear Sways - Work Emotion Bronze XD9 18x8(Front) 18x9(Rear) wrapped in Falken FK-452s - JDM Clear Corners - Blue LED Map/Rear Dome Lights & Courtesy Lights! Hyper-White Side Markers & Parking Lights - Blue LED Lighted Foot Wells - 35% Tint You Will Be Missed (Traded In): Mazda 6i - 5 Door - Blazing Copper Luxury Pkg, Sports Pkg, Moonroof, BOSE Audio, Black Leather! CP-E MAF/CI - OH MY GOD IT RULES! STILL RULES! Umnitza DDE Halos, Prolumens 6000K HID, PIAA Xtreme 1157 Turn Signals. PIAA XTreme Cool Blue White High Beam Bulbs. Rear/Back Windows - 20 Tint & 35 on Fronts. Red LED Map/Rear Dome Lights. Hyper-White Courtesy Lights! Anzo Clear Side Markers. Hawk Performance Brake Pads. MazdaSpeed Lowering Springs for a 1.25" Drop. Calipers Painted Black with Silver Mazda Caliper Stickers. 17" Kosei K1-TS Light Gray Wheels Wrapped in Fuzion Zri! Metra Kit with Pioneer AVH-P5700DVD (Ohhhhh the movies while in the car). PAC-X for Steering Wheel Controls to the new HU. |
