Info from lawsjoe:
Pre-Amp out for Bose Front Left- + Solid Black - Solid Green Front Right- + Solid White - Solid Red Rear Left- + Red w/silver dash - White w/ silver dash Rear Right- + Green w/ silver dash - Black w/ silver dash http://www.cardomain.com/memberpage/388592 # MAZDA'S STANDARD BOSE DESCRIPTION From HU REFERENCE SYSTEM SYSTEM here is the order of what you sould read: number, reference form Mazda(letter) Bose system color and description. 1 a RED BLACK LF+ 2 b RED BLUE/RED Batterie + 3 c GREEN LF- 4 d RED RF+ 5 e LGREEN/RED Data 6 f WHITE RF- 7 g BLACK/YELLOW Data 8 i GREEN/RED Illumination 9 j BLACK Remote 10 n RED/BLACK Steering 11 p GREEN/WHITE Steering 12 r ORANGE Accessory 13 s WHITE LR+ 14 u RED LR- 15 v BLACK RR+ 16 w BLACK/ORANGE Ground 17 x BLUE GREEN RR- http://www.mazda6club.com/gallery/albums/u...cs/wiringHU.jpg
2003 Mazda 6s Steel Grey, loaded, Eibachs, Eyelids, Door sills, tint 2001 Yamaha YZF-600R Black/Silver, V&H slip on, blacked out windshield Moderator, Mazda6Club Administrator, Mazda3Forums, SmallVolvos, FordFusionClub QuickCobalt.com - Chevrolet Cobalt Club Boston Area People: http://www.bigbostonboard.com/ |
Below is a little more information on the subject. Much of the information was gathered from "Phatalone". Most is the same as original post with a few extras like speaker wire color to the speakers
Pre-Amp out for Bose To Speaker (not sure about + - on this side) Front Left- + Solid Black Red/Silver double dash - Solid Green white/silver double dash Front Right- + Solid White Blue/Silver - Solid Red yellow/Silver Rear Left- + Red w/silver dash Pink/Silver stripe - White w/ silver dash Purple/Silver stripe Rear Right- + Green w/ silver dash White/Blue stripe/Silver dash - Black w/ silver dash Black/Blue stripe/Silver dash Black/Red stripe Sub Blue/Black stripe 12v acc Yellow/Black 12v constant or Batt Brown Sub Black/Orange stripe Ground http://www.cardomain.com/memberpage/388592 # MAZDA'S STANDARD BOSE DESCRIPTION From HU REFERENCE SYSTEM SYSTEM here is the order of what you sould read: number, reference form Mazda(letter) Bose system color and description. 1 a RED BLACK LF+ 2 b RED BLUE/RED Batterie + 3 c GREEN LF- 4 d RED RF+ 5 e LGREEN/RED Data 6 f WHITE RF- 7 g BLACK/YELLOW Data 8 i GREEN/RED Illumination 9 j BLACK Remote 10 n RED/BLACK Steering 11 p GREEN/WHITE Steering 12 r ORANGE Accessory 13 s WHITE LR+ 14 u RED LR- 15 v BLACK RR+ 16 w BLACK/ORANGE Ground 17 x BLUE GREEN RR- http://www.mazda6club.com/gallery/albums/u...cs/wiringHU.jpg 2004 Mazda 6s Sedan w/ Bose Stereo Information Front Doors 6.5" door panel cutouts stock speaker size: 156mm Impedance: 2ohms .75" tweeters in door sail panel Drop-in aftermarket replacements: 6.5" components with .75" tweeters This a quite common size and should be very easy to get a good set of aftermarket speakers. Rear Doors 5"x7" door panel cutouts stock speaker size: 5.25" Impedance: 2 ohms Drop-in aftermarket replacements: 5"x7" coaxials or woofers 5.25" coxials or woofers Once again these are very common and should be very easy to get a good set of speakers. Subwoofer 9" cutout stock subwoofer size: 9" Modified fit replacements: Any sub woofer with a diameter under 9" should mount into this unit fine with an appropriate custom adapter. This would include most 8" subs that I know of. However, if you are going to run the subwoofer with out an enclosure behind it I would highly recommend that you ensure the sub is designed for infinite baffle setups. I have installed an 8" in the rear deck and the sound quality is very much improved over the stock sub and can provide a decent amount of bass without taking up much trunk space. |
I have a JL Audio IB4 to put in there.. what did you use to make an adapter with to get it to work??
Please help! Scott
![]() ![]() 2004 Mazda 6S 5-Speed Manual Bose Sound System Mods: Magnaflow Catback/ Airbox Mod / Window tint Future Mods: Rims/Tires, springs, short throw shifter |
I spent some time on mazdatechinfo.com yesterday, browsing through service manuals and wiring diagrams for the 2004 and 2005 Mazda6. I made a pin out diagram of the main audio connector on the Bose systems.
![]() These are 3025 x 2059 gifs, so I'll just link to them here. Audio (Bose) Wiring Diagram A.gif Audio (Bose) Wiring Diagram B.gif Audio (Bose) Wiring Diagram C.gif Audio (Bose) Wiring Diagram D.gif Here's the color codes for the wiring diagrams
2005 Mazda6s 5-Door : 3.0L V6 : 5 Speed Manual : Lapis Blue Metalic Bose Audio and Moonroof Package : Luxury Package : Black Leather Let me know if you like my mods so far. http://www.cardomain.com/ride/707277 |
Regional Moderator
Okay so if this is correct than the BOSE sub inputs are sourced back to the amp not the headunit. So if I want to run 2 amps I'd have to find a 4ch with a preout for the subs?
CANADA / TORONTO MAZDA6CLUB MODERATOR Current Dyno - 205whp, 180wtq |
Has anyone already posted the pin out of the factory amplifier and not the head unit?
I don't want to waste the time writing it up if its already been done.
MECP Certified Car Audio Installer Tweeter Salesman - Part Time Audio/Visual System Designer - Full Time Crestron and AMX Certified Control System Programmer |
#7 (permalink) |
Factory Bose Amplifier Plug Pin Out:
Color Code above applies http://www.msprotege.com/members/1sty/mazd...e%20ampplug.bmp A - Rear Left Speaker Output (-) B - Front Left Speaker Output (+) C - Rear Left Speaker Output (+) D - Front Left Speaker Output (-) E - F - G - Front Left Head Unit Input (-) H - Front Left Head Unit Input (+) I - Rear Left Head Unit Input (-) J - Rear Left Head Unit Input (+) K - Front Right Head Unit Input (-) L - Front Right Head Unit Input (+) M - Rear Right Head Unit Input (-) N - Rear Right Head Unit Input (+) O - Subwoofer Amp Line Output (-) P - Subwoofer Amp Line Output (+) Q - Remote Turn on From Head unit R - S - T - U - Constant 12 Volt Power V - Ground W - Front Right Speaker Output (+) X - Rear Right Speaker Output (-) Y - Front Right Speaer Output (-) Z - Rear Right Speaker Output (+)
#9 (permalink) | |
This should be, at least on the 2005 Bose: X - Rear Right Speaker Output - WHITE/BLUE (+) Z - Rear Right Speaker Output - BLACK/BLUE (-) Rick |
#10 (permalink) |
I am trying to use the existing wiring for the Bose sub to hook up an Infinity Bass link. The Bose sub harness is in my hand and I have the following wires:
blue\red stripe black yellow brown black\orange stripe I have searched this forum and the internet for an hour and have not been able to find a clear answer on what each wire is for. I assume the following: blue\red stripe is constant power black is ground yellow is remote power brown is rear + black\orange stripe is rear - Can anyone please tell me if this is correct???? I hooked the bass link up using this assumption and the amp did not power up. Any help would be appreciated. |
