jerking at 40 mph - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 2Likes
post #1 of 18 (permalink) Old 08-05-2012, 07:58 PM Thread Starter
jerking at 40 mph
My 2003 6 S ATX just hit 140k, and i tried to search forum for a possible solutions but sometimes it to overwhelming. Basically, when i accelerate from 40 mph to 50 (possible 3rd to 4th gear ) i have 2 to 3 quick jerks. It doesn't happen every time but defiantly when i have A/C on. Only once without A/C. It been going on for half a year now and not getting worse yet.
So i have tried "Manual mode" for 3 and 4 gears and there is no problem, also i have drained (flushing wasn't recommended) ATX and filled with mazda M-V. It shows more frequent when its hot i.e afternoon or 20 min of driving. I was thinking maybe one spark plug is faulty firing sometimes (it time to change them anyways), i will drain one more time since its only takes out only 3 qt at a time.
All three jerks happen only at acceleration with-in 1 sec, they are not hard but noticeable. Any experience/suggestions are welcome.
gray03 is offline
post #2 of 18 (permalink) Old 08-05-2012, 08:52 PM
It sounds like a misfire. Check your plugs, wires, and coils.
Sent from my PC36100 using AutoGuide.Com Free App
DrFeelGood likes this.
gen1MZRman is offline
The Following User Says Thank You to gen1MZRman For This Useful Post:
gray03 (08-07-2012)
post #3 of 18 (permalink) Old 08-05-2012, 10:00 PM
6Y MAZDA's Avatar
Quoted: 646 Post(s)
Groans: 27
Groaned at 46 Times in 41 Posts
iTrader: 2 reviews
dude, quit jerking it in your car!
2016 Mustang GT
1997 Jeep ZJ
SOLD:1996 Miata
SOLD: 1967 Chevy C10 Stepside
SOLD: 2006 BCM MS6 GT #00584
SOLD:
6Y MAZDA is offline
post #4 of 18 (permalink) Old 08-05-2012, 10:11 PM
Jjkalai's Avatar
Quoted: 123 Post(s)
Groans: 6
Groaned at 8 Times in 6 Posts
40mph is pretty fast. I hope the window wasn't rolled down. lol
Cobb AP - CP-E Nano SRI - CP-E Single exit CBE - CP-E RMM - PG TIP - SLS TP - Forge V1 BPV - HKS Hipermax LS+ Coilovers - Car_LED Tails - Prosport Gauges - Dashhawk - JBR SSP/Counterweight/Bushings/Heavy Shift Knob
- SOLD
Instagram: JKalai
Jjkalai is offline
post #5 of 18 (permalink) Old 08-06-2012, 01:12 AM
austinairport's Avatar
Groans: 42
Sort of sounds like slipping. But you never know.
Also check your motor mounts.
2004 Mazda 6i ATX -Ksport - Magnaflow - Motegi -
austinairport is offline
The Following User Says Thank You to austinairport For This Useful Post:
gray03 (08-07-2012)
post #6 of 18 (permalink) Old 08-07-2012, 10:59 PM Thread Starter
Jjkalai, 6Y MAZDA yeah i knew someone will come to this, i thought about re-wording title but it gets people attention. Austinairport i don't know man, i thought if it was slipping it would also showed up on manual mode, but it seems smooth shifting there (more puns?). Maybe gen1MZRman is right some corrosion 'fungus' been growing on negative terminal. For nine years nothing, but all the sudden it shows up (have no idea if that is relevant).
gray03 is offline
post #7 of 18 (permalink) Old 08-11-2012, 02:21 PM
last time I had that experience it was a misfire.
ran diagnostics and found misfire on cylinder 6, replaced coil and I'm back on the road
2004 MAZDA 6S 5 DOOR HATCHBACK,STEEL GRAY, ATX
KNN CAI, MAGNAFLOW EXHAUST
TRUECOOL LPD TRANNY COOLER
EVOKE 17X7 GUN METAL RIMS, 225/45/17 ZR NEXEN N3000 TIRES
seigfredm is offline
post #8 of 18 (permalink) Old 08-14-2012, 10:40 PM Thread Starter
I guess it's a dumb question. Am i off to Mazda stealership or local auto-zone can pick which cylinder misfires? i thought the check engine light would come up if any cylinders misfires. I could be wrong (no light on).
i was pondering if it could be a dirty fuel filter, since it doesn't happen every time and only when i accelerate.
gray03 is offline
post #9 of 18 (permalink) Old 08-14-2012, 11:07 PM
A misfire will only throw a CEL after so many misfires have occured, your car probably hasn't reached that number yet. I would go to auto-zone or advanced and see if they can tell u which cylinder(s) is misfireing, as it will be a free check and the stealership will likely charge upwards of $100 to diagnose it. Though, I think, auto-zone or advanced only have code readers and cannot tell which specific cylinder is misfireing without a code. I could be wrong about that.
post #10 of 18 (permalink) Old 09-04-2012, 01:20 PM Thread Starter
It's has been 3 months since this jerking started to happen. And i was wondering if it was a misfire it would have been escalation to a CEL by now. I have noticed that a squeaky sound coming off exactly when slipping/jerking happens (sound like a door hinge). This is just an observation but could it be a belt being loosen up. Jerking happens only at acceleration phase and belt being loose, it slips when rpm gets to 3000 (~40mph). It happens rapidly (loosing and tightening), last time i checked i didn't see any cracks in it, but it might be 'polished glossy' on the inside. Let me know if anybody have any suggestions.
gray03 is offline
