Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > Technical / Performance / Model > Mazda6 1st Generation (2002-2008) > Engine / Drivetrain > ATX Transmission Discussion
Old 10-07-2009, 11:08 PM   #1 (permalink)
Unhappy
What preformance mods can you put on a 07 Mazda 6i. I know air intakes and exhaust kits but what else. Still new at aftermarket parts.
Smoken crows is offline   Reply With Quote
Old 10-08-2009, 04:03 AM   #2 (permalink)
MrTea's Avatar
not sure why this is in the ATX forum, but take a look at the stickies at the top of the 2.3 section and that will set you up with most info you'll need to know about mods.
