Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > Technical / Performance / Model > Mazda6 1st Generation (2002-2008) > Engine / Drivetrain > ATX Transmission Discussion
Old 09-18-2009, 10:11 AM   #1 (permalink)
Hi,
I need to find the location of the transmission drain plug. I want to drain and refill my ATX at every oil change for the next year or so but could not figure it out.
Any pics/diagrams?
It should be the same as the 2006 adn 2007 6s model
Thanks
Vani
vanib is offline   Reply With Quote
Old 09-20-2009, 01:04 AM   #2 (permalink)
QUOTE (Vani @ Sep 18 2009, 07:11 AM)
Hi,
Any pics/diagrams?
Thanks
Vani[/b]
CLICK HERE FOR DIY GUIDE
here you go boss hope it helps
kcfan is offline   Reply With Quote
Old 09-20-2009, 02:36 PM   #3 (permalink)
Thanks for all these articles. Will definitely be useful in the future.
However the ATX change for 6s seems to have been written in 2004. So it does not cover the 2005-2008 version where the tramsmission was changed
Any other clue where I could find an article related to ATX fluid change for Mazda 6s 2005 wagon?
Thanks
Vani
Old 10-29-2009, 07:43 PM   #4 (permalink)
I wrote the whole ATF Flush for my 2007 Mazda6 4-cyl 5sp AT here:
http://www.imazda.com/forums/showthread.php?p=170140
HTH
2007 Mazda6 4-cylinder Auto 40K miles
cn90 is offline   Reply With Quote
Old 10-30-2009, 09:07 PM   #5 (permalink)
karlt10's Avatar
QUOTE (Vani @ Sep 20 2009, 01:36 PM)
Thanks
Vani[/b]
The '05 6-speed drain plug is immediately inside the driver's side front wheel about 12" or so. It is the only hex/Allen head plug facing downwards, so you won't miss it. Sears (and others) sell a 10mm hex socket, or you can just use a 10mm Allen wrench.
The fill plug is kinda under the air box. It can be seen without removing the airbox- just look behind the airbox a bit. It is also a 10mm hex head so you might as well just pick-up the 10mm socket and use it on an extension for the fill plug.
Refill is very straight forward since the dip-stick tube is not also the fill point. That keeps you from having fluid running down the inside of the tube and screwing with your reading.
If you need to know how much fluid Mazda recommends after a drain, just let me know- I've also got an '05 wagon and the factory manual.
MAKE DAMNED SURE YOU GET THE CORRECT FLUID! IT IS TOYOTA T-IV.
Some see the glass as half-full.
Some see the glass as half-empty.
I see the glass as needing a coaster.
2005 6S wagon: MazdaSpeed springs / Tokico HP shocks / MazdaSpeed sway bars / Racing Beat end links / GTSpec Trailing Braces / MazdaSpeed CAI / EGR mod / Racing Beat exhaust / Street Unit engine mount / switching to StopTech braided lines / Hawk HPS pads / B&M tranny cooler - Inline tranny filter - Redline D4 fluid / Mazda iPod adapter - CX-7 antenna / Hella FF50 lights-----Need to be getting in gear on installing: MSDS headers & Magnaflow cat; lightweight pulleys----- Considering-- Fluidamper; oil cooler
karlt10 is offline   Reply With Quote
Old 11-04-2009, 06:10 PM   #6 (permalink)
QUOTE (KarlT10 @ Oct 30 2009, 09:07 PM)
MAKE DAMNED SURE YOU GET THE CORRECT FLUID! IT IS TOYOTA T-IV.[/b]
JohnS6s is offline   Reply With Quote
Old 02-01-2010, 12:13 PM   #7 (permalink)
z00mer's Avatar
Send a message via Yahoo to z00mer
Correct me if I'm wrong, but if you're just doing the drain/refill method, the tranny will need just under 4qts.(3.25-3.75qts) IIRC.
Also...
Red Line D4 ATF FTW!!!!
05' 6s Hatch ATX (Black Onyx/Tan)
http://squintzy.mybrute.com
z00mer is offline   Reply With Quote
Old 03-11-2010, 07:00 PM   #8 (permalink)
I have a 2007 wagon, with the 6spd auto trans....
Do I have a filter to change out as well in the pan, or is it just drain and refill??
Also, what about the rest of the fluid trapped in the radiator and all the inner works??
Is the Redline fluid better than the stock stuff?
I'm in SoCal, and mostly drive in heat, not cold.
Thanks in advance,
Target
target is offline   Reply With Quote
