I have a 2004 Mazda6 2.3i. Last August while on a road trip I noticed my transmission was slipping in fourth gear. I flushed my fluid, and all seemed to be well, until just now when it started doing it again. I've only drive ~5k miles since then. It works fine when in the other gears, and it doesn't do it *all* the time. It seems to be erratic.
What should I do about this problem? I'm hesitant to just go to a transmission shop because of the costs of a rebuild =\. Thanks. |
#2 (permalink) | |
QUOTE (vortex42 @ May 30 2009, 09:13 PM)
might want to explain the symptoms you are having. hoping the issue isn't when flooring it from cruising at about 3k or so....cause that's design for the most part, not slipping.
I've been having the exact same problem. It only seems to do it though when driving at low speeds. Usually at about 30-35 mph.
2005 Mazda 6i Current Mods: Custom SS Straight Pipes, AEM Cold Air Intake, Painted Engine Cover and Fuse Box, Nextmod AE Grille, Removed Doorguards, Debadged, Steeda TB Spacer, TB Bypass Mod, TB Grounding Kit, Blackout Sidemarkers, Blacked Reflectors, A/C Vent LEDs, Cupholder LEDs, Rear White Evil M
#5 (permalink) | |
QUOTE (Soulta @ Oct 18 2009, 10:42 PM)
2004 Lapis Blue M6i ATX :F2 Headers, Magnaflow Cat & Muffs, F2 BSD, B&M tranny cooler, VF Eng mount, AWR Trans + Eng mount, Injen SRI, Quantum QT-106 17" rims, R1 Concepts rotors E-line, Techna-Fit SS Lines, Posi Ceraminc pads, Kart Boy hangers, Magnecor wires, tinted tail lights/markers, High-end sound system, Apexcone 6000k HID's, Seibon CF VSII hood, RB sway & springs, Tokico Shocks, AWR links, Megan H-brace, GT Spec trailing brace, SSG AE grill, Adv. Timing, Hardrace Silicone Radiator Hoses |
