OK,
I have searched and done my home work. ATF M-V is not Mercon V per Mazda Bulletin (see attached file). What is everyone using as an alternative ATF fluid? ?Redline D4ATF ?Mobil 1 ATF ? Other brands Any long-term results? ------- cn90 2007 Mazda6 4-cylinder Auto 40K miles
2007 Mazda6 4-cylinder Auto 40K miles |
#2 (permalink) | |
QUOTE (cn90 @ Dec 30 2008, 10:20 AM)
Whomever wrote that PDF is on glue. Page one says ATF M-V (Type M5) is not the same as MerconŽ V Page two specifies REQUIRED SERVICE FLUID: ATF M-V (Type M5) awesome. |
So much for shift quality complaints when not using TypeM5 fluid
I have Mercon V and it seems to have less shift shock then before I swapped the fluid.Maybe the thicker viscosity is what causes that. Im gonna get a bottle of Lubeguard and put it in ,maybe 2. Ill let yall know if it helps any.
The only Good is Knowledge, the only Evil is Ignorance. - Socrates |
#4 (permalink) | |
QUOTE (Mazda6007 @ Dec 30 2008, 11:42 AM)
I don't have any shift shock issues. Once in awhile when cornering aggressively it will select a much lower gear and lurch a little bit (from like 5th or 6th to 2nd or 3rd) but I drove a CPO Lexus ES330 and it was MUCH worse so I don't really worry about it. Lubegard is highly regarded stuff. I've never heard anybody complain about it's performance except for those that expect a "repair in a bottle" and nothing was going to make them happy anyway. |
I used Valvoline synthetic Mercon V ( after the local Mazda dealer told me thats what they used) i have had it in for the last 15-20 thousand miles and the trans still shifts fine.
#6 (permalink) | |
QUOTE (Spazdog @ Dec 30 2008, 01:59 PM)
I've put Lubeguard in my ATX, along with a cooler and several drain-refills using Redline D4, have made my trans. shift pretty smooth. ( And i have the Jatco)
04' 6S ATX cooler,airbox mod |
#7 (permalink) | |
QUOTE (Ericzoom @ Jan 31 2009, 05:15 PM)
Shift shock is alot better,but I still get it. Though not as bad ,but mainly on colder days. But you can't really expect a fluid to fix shitty transmission shift programming..... The tranny does feel like it puts down slightly more of the power to the ground. Which it does say on the package helps to reduce clutch slippage. If nothing else, if it extends fluid and transmission life like it says .I'd say it's well worth the $16 I paid for it. I would recommend Lubegard to anyone from my experience thus far. want more info,hit up : www.Lubegard.com
#8 (permalink) | |
QUOTE (jiminEcricket @ Jan 31 2009, 10:15 AM)
1. I noticed that Valvoline Synthetic Mercon V is red (I think they added the red dye to the ATF). Can you mix Valvoline Synthetic Mercon V with existing factory Mazda MV without problems? 2. Also anyone can point me to a DIY to disconnect cooler line for a complete ATF Flush? Thanks!
#9 (permalink) |
in my opinion, i think its a long delayed post to have a sticky post on alternative M-V ATF fluid recommendations.
i feel mazda's M-V fluid isn't really good stuff as it degrades fast, and the colour turns brownish-black very easily. please think about it. cheers! |
#10 (permalink) |
I use Amsoil since they have a warranty so if the fluid fails they replace your trans. They guarantee it to be compatible so I use it. I NEVER get shift shock even at an autox.
BUY MY CAR |
