Overfilling ATX fluid, what can happen? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 15 (permalink) Old 08-22-2005, 05:19 PM Thread Starter
Got 13K on an 04 6S. Did a drain/refill at about 6K and overfilled by about a quart. Pretty stupid, i know.
Just corrected fluid level, but am wondering what kind of damage overfilling can cause.
I didn't notice anything during the overfill, other than the typical shock shift and sluggish summer performance.
labelguy is offline
post #2 of 15 (permalink) Old 08-23-2005, 12:04 AM
6GunRocket's Avatar
The extra fluid will create a subatomic flux in the atriatic benzene molecules. Evenually when the transmission reaches maximum temperature a thousand microscopic black holes will open that are linked to Universe 22342 a.k.a. Herpes 9. I'm sorry to say that you now have herpes.
Lang Lebe Deutschland!
6GunRocket is offline
post #3 of 15 (permalink) Old 08-23-2005, 12:37 AM
MadMardigan's Avatar
I don't think any, did it bubble at all out the dip stick area?
3.0L V6 ATX Performance White
MadMardigan is offline
post #4 of 15 (permalink) Old 08-23-2005, 09:35 AM Thread Starter
And here I've been wasting my money on cheap whores in search of those black holes. Nice one 6Gun
Nope, no bubbling, no foaming. Everything seemed fine.
labelguy is offline
post #5 of 15 (permalink) Old 08-25-2005, 03:53 PM
VroomZoom6MZR's Avatar
you should be ok if it is now corrected. Just keep us posted if you notice anything out of the ordinary.
VroomZoom6MZR is offline
post #6 of 15 (permalink) Old 08-16-2007, 08:41 PM
*ICE*'s Avatar
anything??? i filled up 4.5 qt today.... but i have a tranny cooler, does it help a bit?
NO LONGER AN ACTIVE MEMBER OF THIS FORUM. PLEASE DO NOT PM ME. i WILL NOT RESPONSE
*ICE* is offline
post #7 of 15 (permalink) Old 08-16-2007, 08:58 PM
shutterbug2020's Avatar
Send a message via AIM to shutterbug2020
anything??? i filled up 4.5 qt today.... but i have a tranny cooler, does it help a bit?[/b]
My tranny fluid is over the full mark by a bit also. I have a cooler (B&M) and the extra comes into play when the cooler is fully open. The level is where it needs to be for that. I checked it when it was hot after running really hard. The herpes comment is hilarious!!!
Bright Island Blue 06 6s
shutterbug2020 is offline
post #8 of 15 (permalink) Old 08-17-2007, 09:09 AM
VirtualMirage's Avatar
I have a tranny cooler too and when I installed that I added about .5 quarts (had to guesstimate since I couldn't find any specific recommendations) to compensate for the cooler, the longer hoses, and any fluid lost during hose removal. And yes, I ran mine inline with the radiator. Ever since then my fluid level reads just a hair over the top full mark when cold and a little more when hot. I think it's hard to get an accurate measurement with the tranny cooler since it works on a "thermostat" basis, so the amount of fluid the cooler will have will vary depending on how hot the transmission fluid is. I was told to not worry about it too much since it was only just .5 quarts and I do have the cooler installed. I was also told since it's so little the most it will probably do is cause just a little more drag on the transmission, thus a little more heat or loss in responsiveness. But thus far I have noticed none of those side effects. I will probably fill it up more accurately when I do a drain on it in the near future.
Any advice to this?
Paul
2007 Mazda6s GT 5-Door, Tungsten Grey (Auto, 6-speed) :
1/4 Mile: 15.609s @ 89.69 MPH <-- MIR, 3/1/08. Burnout done for traction, Brake torqued around 1700RPMs, Wheelspin off the line. Low trap time due to Cyl #6 misfire.
0-60 MPH (60.3 actually): 6.45s <-- Timed with MSD DashHawk (TCS off, D Mode, no brake torque, some wheelspin off the line). Repeatable. Time should improve with better launching and better tires.
Dyno/Tune (Conservative timing adjustment) 1/26/08 ---> 182.53 HP / 172.33 TQ at the wheels (SAE format)
VirtualMirage is offline
post #9 of 15 (permalink) Old 08-17-2007, 07:55 PM
*ICE*'s Avatar
well, i checked mine today again when its cold and the level is above the twisting part of the dip stick, way above the mark for HOT.....
i thinks its bad!! but i will drive for about 1000 miles and update the status then
*ICE* is offline
post #10 of 15 (permalink) Old 08-17-2007, 09:00 PM
ShaDrag's Avatar
If you are that far above the full mark I would take some out before any potential damage is done. Better safe than sorry.
ShaDrag is offline
