What's your max mileage on a 3.0 V6 ? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 1Likes
  • 1 Post By nooch
post #1 of 7 (permalink) Old 10-12-2017, 12:01 AM Thread Starter
Hi, how long can it run a Mazda 6 with a 3.0 V6?
can you reach 200-250k miles without many troubles? (automatic trans)
what's your mileage with this engine?
thanks
mjbkj is offline
post #2 of 7 (permalink) Old 10-12-2017, 01:50 AM
toy4x's Avatar
Quoted: 195 Post(s)
My 05 v6 has 280,000 miles.
Mostly routine maintenance till around 200k.... Suspension lower control arms/ shocks/ spark plugs etc... Almost exactly at 200k, radiator blew and exhaust manifold cracked. Both of which are a complete bitch to fix.
Engine and trans still running strong... both on synthetic.
2016 Mazda 6 GT Reflex Blue Mica
Black Chrome 19" Stock Wheels
Formula 1 Pinnacle Ceramic Tint 30% * Air Blue 80 Windshield Tint
OEM Splash Guards
AIO Tweaks
Tanabe Medalion Exhaust & NF210 Lowering Springs
Koni FSD Shocks / Struts
toy4x is online now
post #3 of 7 (permalink) Old 10-12-2017, 07:58 AM
Shiro Shinobi
Byakuya's Avatar
Quoted: 2677 Post(s)
There's a good handful of people in the 200k+ range. Most cars are perfectly happy getting to the 200k+ range so long as you care for them properly and don't thrash on them.
There was a thread on here somewhere about people and their V6 milage but I can't seem to find it.
Current:
, Sold:
, 3rd Generation
Need a Part Number? Find it
Byakuya is offline
post #4 of 7 (permalink) Old 10-12-2017, 09:16 AM
b1lk1's Avatar
Quoted: 214 Post(s)
Groans: 17
My 04 V6 has ~270,000KM (about 168,000 miles) and it still runs beautifully. I still get great gas mileage and plenty of power still on tap. You should easily see 250,000 miles if you do maintenance and you don't treat it like a rental car.
Don't forget that an automatic transmission IS a wear item and not designed to last the life of the car, just like a clutch. If you manage to keep your auto transmission alive for 250,000 miles or more then you are caring for it well, but they do by nature consume themselves at a slow rate so having to rebuild it once should be considered maintenance, in my opinion at least.
2004 Mazda 6s 3.0 5dr. never ending money vacuum project:
b1lk1 is offline
post #5 of 7 (permalink) Old 10-16-2017, 08:06 AM
HerronScott's Avatar
Quoted: 152 Post(s)
327,000 miles on my 2004 6s before I lost compression in one cylinder. Manual transmission though with one clutch replacement. Had to replace the water pump, alternator, accordion intake hose, dogbone motor mount, 1 front axle and 1 front axle boot and both pre-cats but otherwise normal maintenance parts.
Scott
2004 Mazda 6s GT MTX sports package
HerronScott is offline
post #6 of 7 (permalink) Old 07-05-2018, 10:05 PM
i hit 370,000 miles yesterday on my 2005 6s atx 5-door. bought it new so i've had it all this time. original engine and transmission. had to replace the control arms a couple months ago, it rides nice and tight now. last year i replaced the starter and valve cover gaskets and intake manifold gaskets. other than the replacing the intake hose and maf sensor a few years ago, i've only spent $$ on normal maintenance stuff. leaks a little bit of oil...a quart every 1000-2000 miles so it's not that bad, but it drips onto the exhaust manifold...i'm pretty much over the smell of burning oil, but i'm not gonna spend the $$ to fix the leak
HerronScott likes this.
nooch is offline
post #7 of 7 (permalink) Old 07-05-2018, 10:25 PM
bluedevil6's Avatar
Quoted: 8 Post(s)
370k! Damn, mines only at 156k the most I've had on anything was 220k on a 98 ram 1500.
2007 6 Hatch 3.0 V6 ATX
Mods-tinted windows, trans cooler, triple gauge dash pod with Trans Temp-Oil Pressure-Voltmeter, EGR tube delete, TB coolant bypass, rear muffler delete
Mods to come
- lowering springs, cold air intake, gut cats
Audio- OE NON-Bose HU with 4 Boss Audio door speakers powered by 1000 watt Crunch amp with OE Bose sub
bluedevil6 is offline
