Trouble Codes O2 sensor - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 8 (permalink) Old 03-20-2017, 11:50 AM Thread Starter
Brian Doyle's Avatar
I just bought a 2006 Mazda 6 and it came with a P2189 trouble code. I know it points to the Front O2 sensor, but could be a number of things. The car runs perfectly. No hesitation, isles fine, no loss of power. It also throws a P2092 Camshaft Position code every 4-5 turn on cycles. I guess my question is, should I just go and replace the O2 sensor and then reset the CEL and see if anything else comes up, or is there an easier less expensive thought I should try first?
Thanks
Brian Doyle
2006 Mazda 6 v6
Brian Doyle is offline
post #2 of 8 (permalink) Old 03-20-2017, 01:10 PM
toy4x's Avatar
Quoted: 110 Post(s)
2189 can be multiple of issues. 02 sensors, leaky manifold gaskets, vacuum hoses... Etc. First thing check the easy stuff. Check all the vacuum hoses and the air accordion for leaks and cracks. Easy way to do this is to spray throttle body cleaner on the hoses while the car is running. If there's a leak, you'll hear the engine rev up a bit.
When you fill up on gas, is it hard for the car to start? 2189 can also lead to a purge valve.
As for the p2092, replace your Camshaft sensor
Sent from my SM-T567V using Tapatalk
2016 Mazda 6 GT Reflex Blue Mica
Black Chrome 19" Stock Wheels
Formula 1 Pinnacle Ceramic Tint 30% * Air Blue 80 Windshield Tint
OEM Splash Guards
AIO Tweaks
Tanabe Medalion Exhaust & NF210 Lowering Springs
Koni FSD Shocks / Struts
toy4x is online now
post #3 of 8 (permalink) Old 03-20-2017, 01:48 PM Thread Starter
Thanks. I'm going to try that. Yeah, I only filled it up once since I bought it, but it did for a second have a hard time starting afterwards. I'll check for leaks and replace the camshaft sensor and purge valve. I'll let you know how it went. Thanks again.
Brian Doyle
2006 Mazda 6 v6
post #4 of 8 (permalink) Old 03-20-2017, 04:12 PM
Quoted: 27 Post(s)
Before buying a new camshaft sensor you may want to pull them out and wipe off the metal dust that sticks to the magnet. Might be a real cheap fix.
2004 Wagon S 3.0, 5-speed ATX, Performance White (A2N) 167,000mi
DrFeelGood is offline
post #5 of 8 (permalink) Old 03-20-2017, 04:19 PM Thread Starter
Awesome!!! I'll give that a go.
Brian Doyle
2006 Mazda 6 v6
post #6 of 8 (permalink) Old 03-26-2017, 09:23 AM Thread Starter
So I finally got around to replacing the camshaft sensor. Actually, I replaced both sensors, the purge valve and an O2 sensor. I reset my CEL and immediately, it blew a P2092. Camshaft sensor again. Both are new. Any thoughts??
Thanks!!!
Brian Doyle
2006 Mazda 6 v6
post #7 of 8 (permalink) Old 03-26-2017, 11:21 AM
Quoted: 27 Post(s)
Thanks!!!
Ugh, too bad that didn't work. I have a 2004 so My info may be a little different. I will include what I have from my 2004 workshop manual (part# 9999-95-063B-04R).
At this point it may very well be a wiring issue.
ID:	201345   Click image for larger version
ID:	201353   Click image for larger version
ID:	201361   Click image for larger version
post #8 of 8 (permalink) Old 03-28-2017, 11:49 AM Thread Starter
I just talked to a mechanic and he says I need a Camsaft Actuator. Costs $1200. He says a shop has to replace it. Any suggestions? That's almost half of what I paid for the car 2 weeks ago... ��
Brian Doyle
2006 Mazda 6 v6
