Air Box Mod Idea? - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Go Back   Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum > Technical / Performance / Model > Mazda 6 1st Generation (2002-2008) > Engine / Drivetrain > 3.0L V6
New User? Register
Old 01-25-2013, 09:12 PM   #11 (permalink)
ButtonPuncher's Avatar
It doesn't make sense. But that's emissions for you. Same reason EGR routes 1500 degree exhaust gases back in to the intake.
If mfg's wanted to make the most powerful and efficient engines from the factory, they'd all have CAI's with no resonators, no EGR, 160 degree thermostats, oil coolers, piston oil squirters, high flow cats, long tube headers, true dual exhausts, electric water pumps, electric power steering, direct injection, and variable valve timing on both cams.
I apologize to the OP for taking this somewhat off topic.
'06 6s 6-speed ATX - Lapis Blue - just getting started
BP 6s DIY CAI, MPV Oil Cooler, Innovate OT-2 Data Logger, The right turbo for your 3.0, Walbro fuel pumps
ButtonPuncher is offline   Reply With Quote
Old 01-25-2013, 09:17 PM   #12 (permalink)
Love Dem Beads
Mr.Smoke's Avatar
Groaned at 4 Times in 4 Posts
Quoted: 773 Post(s)
Default Air Box Mod Idea?
Ya i hear that. Poor choices IMO.
Mr.Smoke is online now   Reply With Quote
Old 01-25-2013, 11:24 PM   #13 (permalink)
Groaned at 2 Times in 1 Post
For some of those, its mostly to make it a livable car as well. As for the long tube headers and high flowing exhaust comes the price of loud exhaust. why they run hot air back through the intake? look back to the old carbed engines, its also to speed up the engine warming process. running 160F T-stats? im pretty sure Heaters would only get warm and not hot on the coldest days. Ive heard electric power steering leaves a little to be desired in the road feel department as well. Engines will always suffer a little in performance for the comfort and lower cost to the consumer.
I could be wrong on some of those though. Just my thoughts.
StevenMazda6S is offline   Reply With Quote
Old 01-26-2013, 06:55 PM   #14 (permalink)
Nah. 160 is fine for cold climates. I ran them in all of my Ford Contours and I live in WI. Even with a broken thermostat that is stuck wide open, the air will still get a little warm.
You're right on electric power steering. It's not there yet. But it's getting there. Just look at how throttle by wire has progressed. I can barely tell most of the time.
