Vibration and pull - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Go Back   Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum > Technical / Performance / Model > Mazda 6 1st Generation (2002-2008) > Engine / Drivetrain > 3.0L V6
New User? Register
Old 12-28-2012, 09:35 PM   #1 (permalink)
Default Vibration and pull
Ok I just took a trip for the holidays and I just noticed a pull hitting every other second twards the passanger side but just while giving it gas once I let off it stops or if I open it up it stops and for about 50 or so miles the same thing and then got faster and faster untill a full vibration took over and pued really hard to right and again as soon as I let off the gas it stops, so then I let it vibrate 2-3 minutes without letting off and then it stops on its own so I though something just got in a binde and 40 or so miles later it repeats slow at first and tbe full out vibration, also it not a balance thing because it does this throughout the speed range. Any one had this problem before if so please help
Dyeary32 is offline   Reply With Quote
Old 12-29-2012, 08:29 AM   #2 (permalink)
oviedo6's Avatar
Have a tire shop take a look at you tires or do it yourself if you can. A few years ago I had one of my front tires start separating which caused vibration and pull. Replaced the tires and it was fine.
"Love Thy Neighbor as thyself. What, am I supposed to jerk him off too?"--Rodney Dangerfield 1921-2004
2004 Steel Gray Metallic Sedan, ATX, Alpine CDA-9855, Boston Acoustics Separates, JL Audio 300/4 and 250/1, JL Audio 12" Sub, Lower Fogs, HID's, Amsoil. More to come.
oviedo6 is online now   Reply With Quote
Old 12-29-2012, 03:06 PM   #3 (permalink)
Final Impact's Avatar
Quoted: 194 Post(s)
^^ that'd be good first step. You never said what end of the car? We have the when, what about the "Where?"
I would also be suspicious of a stuck caliper i.e. brake is dragging. Note a rear brake CAN make a car pull. Don't think its isolated to the front. The rotor color may be tell tale sign. Darker in color and headed towards blue says its getting hot.
>79,000
Old 01-08-2013, 07:53 PM   #4 (permalink)
Oh sorry its the front passanger and rotors are good
Old 01-08-2013, 09:24 PM   #5 (permalink)
elemento_74's Avatar
Quoted: 34 Post(s)
Jack up the car and check for wheel play.
Sent from my SAMSUNG-SGH-I727 using AutoGuide App
K&N CAI,Magnaflow exhaust,HID driving & fog lights,DoubleDin stereo with NAV,VIS carbon fiber hood,Autoexe grill & lip,Motegui 18' rims with Hankook tires,speed6 brakes,Steel braided lines,TB coolant bipass,TB grounded,PKE alarm system,Mazdaspeed short shifter
elemento_74 is online now   Reply With Quote
Old 01-09-2013, 11:13 AM   #6 (permalink)
Quoted: 194 Post(s)
What, when, where, - " WHO?? "
Ha - how many miles on it?
Any previous work done like brakes? Has it ever been wrecked or curbed hard enough to change the steering wheel position when driving straight?
>79,000
Old 01-11-2013, 10:38 PM   #7 (permalink)
72 k on it and no wreck or curb impact but breaks about 3 months ago and no play at all. Still confused on what it might be but has not done it sence the trip, but hasnt been back on open road sence just town, I did notice grease build up on the inside of the rim but no cuts in the boot of the ale or any joint covers??
Old 01-12-2013, 10:15 AM   #8 (permalink)
Groaned at 3 Times in 1 Post
Quoted: 9 Post(s)
Check your struts/shocks next. If they look good, move on the the shock tower mounts.
06 Black MS6. CS TMIC. CS Short Ram & TIP. Custom resonated test pipe. Block8head guage pod w/ Aeroforcetech Dual Interceptors, SPC adjustable ball joints. Customized CS SSP. Xcarlink for iPhone w/Bluetooth. Zapco AG650/AG360 w/ Boston sub, Dayton mids, and Seas tweeters.
trent.g is offline   Reply With Quote
Old 01-13-2013, 12:32 AM   #9 (permalink)
Ill check that in the morning and let you know
Old 01-17-2013, 06:11 AM   #10 (permalink)
Ok checked everything out and thr only thing I can find is the sway bar stabelizer arm was busted can this cause the vibration? I know it can cause it to pull
