#31 (permalink) |
wait wait wait, the shop was telling you that your poor compression was potentially from a poor injector seal? Please explain this. I would love to hear it.
| Sponsored Links | |||
Advertisement | |||
#32 (permalink) |
Not an injector seal. They said it was possible the injector was clogged/stuck open and could be leaking fuel into the cylinder and washing down the walls. They made it very clear that it would likely need a motor but for $35 for the injector from the dealer it might be worth giving it a shot.
#33 (permalink) | |
banana boat.
Quoted: 116 Post(s)
Stuck open (would dump fuel causing a RICH code, not LEAN) changing an injection isn't going to cure a lack of compression. |
#34 (permalink) |
Quoted: 194 Post(s)
Pull the valve cover and confirm the valve train isn't blown up. 40PSI would be blowing smoke in a big way of the piston rings were that bad.
besides its the easy cover. . .
#37 (permalink) |
Quoted: 194 Post(s)
#39 (permalink) |
Quoted: 194 Post(s)
RIP!
Advertisement | |
