Engine code p0303 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Go Back   Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum > Technical / Performance / Model > Mazda 6 1st Generation (2002-2008) > Engine / Drivetrain > 3.0L V6
New User? Register
Old 10-14-2012, 10:22 PM   #1 (permalink)
Default Engine code p0303
Hello
Ive got 04 mazda 6 wagon v6 . The code talks about a misfire . I replace the coil pack . Thinking that would fix the problem . Which it did for about 60 miles and light back on with the p0303 code again. Im think fuel injector . Is there other thing i should be looking at ?
Thanks
David B
dbmazda is offline   Reply With Quote
Old 10-14-2012, 10:34 PM   #2 (permalink)
ctmazda's Avatar
Quoted: 193 Post(s)
Spark plugs spark plugs spark plugs! Well plug, but they are cheap so you might as well replace them all while you are at it.
P.S.- Did you reset the ecu when you replaced the coil? Aka disconnecting the battery?
This is a 100% must when doing any type of electrical/engine work, especially when working with engine diagnostics/codes.
Also, where exactly was the coil you changed? Many people have the cylinder order messed up on the v6s.
Sent from my iPhone using Autoguide
2004 Mazda 6 Sport V6 MTX-Steel Grey
MSDS Headers/Ported Intake Manifolds + 1/2" Spacer/Injen CAI/3.7L OTB/TGNY TB Spacer/Magnaflow CBE/AWR 88 Mounts/Rotora H2 Ceramic Brakes//CF Evo Hood,Grill,Eyelids,Window Visors,Mirror Covers/CAR-LED Tails/35W 5000k HIDs/55W 6000k Integrated Fogs/LED Fogs/1000w Xplōd Amp/Two 800w 12" Xplōd Subs/15% Tints/18x8.5 +50 Kazera "CF" Rims/Hankook Ventus Evo 245/40/18
Future Mods:Powermod Tuner/Custom DoubleDin/BC Coils
ctmazda is offline   Reply With Quote
Old 10-14-2012, 10:34 PM   #3 (permalink)
Love Dem Beads
Mr.Smoke's Avatar
Groaned at 4 Times in 4 Posts
Quoted: 773 Post(s)
Welcome to the club!!
Spark plugs & all ignition coils.
Mr.Smoke is offline   Reply With Quote
The Following User Says Thank You to Mr.Smoke For This Useful Post:
Final Impact (10-25-2012)
Old 10-14-2012, 11:05 PM   #4 (permalink)
Hello
I did replace all the coils and plugs .
David B
Old 10-14-2012, 11:13 PM   #5 (permalink)
JFisher100191's Avatar
Quoted: 33 Post(s)
I'm going to have to disagree with unplugging it to "reset the ecu" the vehicle does thousands of self checks a minute and will only throw the code when there is an ACTIVE issue. It will retain the history code but won't have a present DTC if there is no present fault.
'12 Mazda 6i Sport:
Smoked markers
Blacked out trim and emblems
OEM Spoiler with LED 3rd brakelight
Many more to come
JFisher100191 is offline   Reply With Quote
Old 10-14-2012, 11:26 PM   #6 (permalink)
Love Dem Beads
Mr.Smoke's Avatar
Quoted: 773 Post(s)
Fisher i must agree with you. However, the battery should be unhooked when changing coils.
Old 10-14-2012, 11:38 PM   #7 (permalink)
Quoted: 33 Post(s)
Agreed with that, anything I ever do with my car, the battery gets disconnected first. You never know when you might hit a plug or pop a fuse and cause a ton of heart ache that could have been avoided. Bit of a pain to always have to reprogram my radio stations but it's worth it in the long run.
'12 Mazda 6i Sport:
Smoked markers
Many more to come
Old 10-15-2012, 01:13 PM   #8 (permalink)
banana boat.
flipper66's Avatar
Quoted: 117 Post(s)
there is still a retained code and the CEL will remain illuminated till the engine has several cycles of not recognizing the issue still existing. Also, the Plug itself will be saturated with fuel if the coil wasn't up to snuff, so it is going to still "have a problem" till the cleans off.
Lastly, resetting returns the ECU to the base map. When there is a code the engine pulls timing and adjust fuel trims to avoid havoc or engine damage. Once the problem is eliminated, resetting back to "all clear" is the proper thing to do.
flipper66 is offline   Reply With Quote
Old 10-16-2012, 04:21 PM   #9 (permalink)
Hello everyone
Here what has been done . Ive put new plugs and coils pak . Yes all 6 plug & coil paks The reason for both plug and the pak was because i got the p303 code and good change the plugs. Which is a misfire code .Also ive reset the car's computer . Ran great for about 60 miles then the p303 code came back. I put a seaform in the gas tank .It seem to be running better . But still got along way to go .
Thanks
David B
Old 10-17-2012, 12:02 PM   #10 (permalink)
banana boat.
flipper66's Avatar
Quoted: 117 Post(s)
Possibly a very dirty injector.
did you replace the plenum gaskets when you did all this work?
