Hey M6ers,
Getting this code on my 03 V6 manual. Starts up and idles fine. When driving however it feel real sluggish and weak. Been doing some searching around here and it seems like either coil packs or a vac leak but before I order them I wanna be sure. When at idle I sprayed starter fluid around the manifold and vac lines but no luck. Pulled the plugs that I just installed last week and 3 are dark/black, 2 are light brown and 1 like yellowish/white. Any info would be sweet. Thanks in advance.
| Sponsored Links | |||
Advertisement | |||
I went ahead and order a set of coil packs. 90 bucks per pack if I was to get em locally.
Gave that a "No Thanks" and placed an order for all 6 for 80 bux. One thing i will check when I get home is plug gap. I just trusted the manufacturer to pregap it correctly before shipping. ??? |
Smoke Screen
![]() Join Date: Dec 2011
Groaned at 4 Times in 4 Posts
Quoted: 659 Post(s)
Always check gap before installing plugs. When i bought my ngk iridiums every plug was out of spec.
Here is something that will give insight as to sprak plug conditions. |
^^ I always checked gap when changing plugs on my old turboed V6 tib but when doing stock vehicles I never thought about it.
One thing I will definatly keep in mind from now on though. Thanks for that link. Very informative |
Smoke Screen
Quoted: 659 Post(s)
No prob glad i could help.
Plug gap is so important. For everything from a 2 stroke weedeater up to million dollar cars. Just my 2¢ |
Understood.
What are the chances of oil leaking thru the valve seals or piston rings into the chamber but no smoke coming out the back?? Thanks!! |
#7 (permalink) |
banana boat.
Quoted: 116 Post(s)
very limited.
did you check the intake boot for rips/tears? |
#8 (permalink) |
Not yet but I sure noticed a good/bad amount of oil in both the intake manifold and piping.
Looks like its coming from da front valve cover. PCV still good but went ahead and ordered a new one. |
#9 (permalink) |
Update: Plug gap was definatly off. Gapped them to .044, put everything back together, test drove it with same issues.
Starts up fine, idles good, lack of power down low and bogges a bit when accelerating. It does smoke out a bit out the back. If coil packs dont fix the prob I may look into changing out valve seals. How can I confirm if the seals are out? Besides the smoke coming out the back what else can I do to confirm it is seals and not something else? Thanks!!!!!! Last edited by SIX_SEVEN_ONE; 10-16-2012 at 08:32 PM. |
#10 (permalink) |
banana boat.
Quoted: 116 Post(s)
leak down test.
again it is very unlikely. |
Advertisement | |
