Removing Passenger CV halfshaft from Intermediate Shaft - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 16 (permalink) Old 02-10-2012, 01:43 AM Thread Starter
I am replacing my CV halfshafts on my 2003 Mazda6S. I am having some trouble removing the CV halfshaft from what I am calling an "Intermediate shaft" that actually connects to the transmission. I already did the driver side and it came right out with no problem. I tried prying it with a bar but there isn't a lot of room to work with under there. In attempting to get it out I popped the inner boot off so I ended up removing the entire shaft to attempt to get it out. Has anyone else had a problem getting this off from the passenger side?
Thanks for your help.
ID:	81545   Click image for larger version
perolapreta is offline
post #2 of 16 (permalink) Old 02-10-2012, 08:17 AM
CanyonRider's Avatar
Quoted: 181 Post(s)
It can be a PITA to get apart. Clamp the intermediate shaft in a vise and use a axle puller with your slide hammer to get the CV shaft out.
You can rent both at AutoZone
http://www.autozone.com/autozone/acc...ifier=2061_0_0
Be sure to replace the carrier bearing.
Good luck!
2003 Mazda 6s MTX
Mods - Yeah, I got
My Threads:
Like our Race Team's Facebook page:
CanyonRider is offline
The Following 2 Users Say Thank You to CanyonRider For This Useful Post:
e4w (09-03-2012), perolapreta (02-10-2012)
post #3 of 16 (permalink) Old 06-06-2012, 07:10 PM
gondlesnorf's Avatar
Quoted: 56 Post(s)
I'm having this problem right now. Driver side was cake (except those damn lower ball joints) I've been fighting this thing for a couple hours. The intermediate shaft is still in the car and the axle separated at the same point. Man, this sucks.
2003 6S MTX, 2006 Fusion engine swap, Fidanza aluminum flywheel, Exedy clutch, Cordova Motorsports 70mm OTB w/ coolant bypass, Custom Spectre CAI, CP-e MAF Customizer, CP-e Wishbone Mount, Magnaflow cat-back, EGR mod, TWM short shifter, Koni FSD, Eibach Pro-Kit, 18" Kazera KZ-J (+55mm), Audiolink MP3 USB adapter, Scangauge II w/ Blendmount, Apexcone DDE Lighting Raptor Edition, 8000k 55w, matte black 1080 wrap.
gondlesnorf is online now
post #4 of 16 (permalink) Old 06-06-2012, 08:48 PM
Quoted: 181 Post(s)
You need to remove the intermediate shaft from the car so you can clamp it in a vise. Then you can separate it from the CV shaft. Good Luck!
CR
2003 Mazda 6s MTX
Mods - Yeah, I got
My Threads:
post #5 of 16 (permalink) Old 06-07-2012, 10:02 AM
Quoted: 10 Post(s)
It usually isn't very hard to separate them if you give it a good whack with a decent sized hammer. You might not know where it's supposed to separate so here is a picture just in case. The circled section is where it separates. Hold the intermediate shaft up in the air with the CV housing hanging down. Whack the housing down at the arrow location. A whack or two should push it over the snap ring and then it will pull right off. You are replacing the shaft anyway so hitting it with a hammer isn't going to matter.
Visit:
for 3L swaps for your Contour/Cougar/Mazda 6 or for general repair work at low rates.
Blackcoog is offline
The Following 2 Users Say Thank You to Blackcoog For This Useful Post:
chilimax21 (03-16-2014), e4w (09-03-2012)
post #6 of 16 (permalink) Old 06-07-2012, 11:46 AM
Quoted: 56 Post(s)
I ended up taking the intermediate shaft out. It was a lot easier than I thought it would be. After that, the separation was very easy. A couple hits with a hammer got it. Thanks guys.
The Following User Says Thank You to gondlesnorf For This Useful Post:
e4w (09-03-2012)
post #7 of 16 (permalink) Old 09-03-2012, 10:25 PM
e4w
e4w's Avatar
Quoted: 32 Post(s)
Send a message via Yahoo to e4w
Thx guys, I'm about to do this in the morning.
[B][SIZE=2]2004 6s MTX/sport clutch/air box mod/de badged/ TB Coolant by-pass /6000K HID/AWR 88D Rear mount/AWR 88D upper trans mount/exh mod
my 6
185.66hp/ 170tq 11/2011
213kmi (Sept 4, 2016) update
e4w is offline
post #8 of 16 (permalink) Old 03-10-2014, 10:57 AM
DB0511's Avatar
Quoted: 4 Post(s)
I'm trying to find a C.V. joint from a Mazda 6 EU model that will fit my 2004 M6 V6. To match the correct part I need to know how many splines there are on the inside of the outer C.V. joint (one that goes into the wheel) of the V6 model, and I don't have a spare one laying around that I could take apart. Does anyone have a old C.V. joint laying around, and could tell me how many spline there are on the inside or could take a pic for me? any help would be appreciated
Here is an example of what I am looking for
DB0511 is offline
post #9 of 16 (permalink) Old 03-10-2014, 11:26 AM
Final Impact's Avatar
Quoted: 532 Post(s)
Groaned at 4 Times in 4 Posts
^^ +1
WARNING!!! Folks, if you hammer on the Trunnion joint (inner joint) while using the CARRIER BEARING AS HOLDING FIXTURE (IN THE CAR) - YOU WILL DAMAGE THE CARRIER BEARING!!! DO NOT HAMMER ON IT WHILE ITS IN THE CAR!
It will last for a while, but it will fail. Remove the axle and simply hold it in the air as Blackcoog suggests. You have the weight axle to help it come apart. The downside is the inner joint may fall apart. This is only a concern if you're reusing it.
If you can get two pry bars up in the car and apply light force on BOTH SIDES of the joint, they usually come right off. Applying force from one side only usually just binds the clip on the shaft locking it tight.
V6 repair info here:
Final Impact is offline
post #10 of 16 (permalink) Old 03-10-2014, 11:27 AM
Quoted: 532 Post(s)
I'm not sure what your timeline is but most of us don't take the joint apart, just swap the axle for a boxed item. My point; this could take some time for someone to post up the info you need.
I suggest you contact one of the groups that rebuild driveshaft components. Either that or head to a wrecking yard if there is such a thing in your parts.
Good luck!
