#21 (permalink) |
very well,so the heads are different castings?i do not have the used engine yet but my research showed same head casting,so i ASSumed simple cam swap and timing.what is the difference in the heads?also,the engine coming out is locked up,dropped a valve or something in middle cylinder radiator bank.i am wondering is valve failure is due to possible cat being stopped up and super heating cylinder.thanks
| Sponsored Links | |||
Advertisement | |||
#22 (permalink) |
banana boat.
Quoted: 116 Post(s)
I don't know about the castings being different, I would assume they are the same. In most cases people don't take the extra effort to swap just the cams, instead of just using the mazda heads.
Radiator bank? |
#23 (permalink) |
front of car...i pretty sure its #4 cylinder.i guess the heads are like the 2.3 and the front cam cap is different from one engine to the other and does not allow interchange.thanks again.i have made my decision to just sell it the way it is.
#24 (permalink) |
banana boat.
Quoted: 116 Post(s)
"radiator bank" as in the front bank. which is bank 2.
#25 (permalink) |
update!!2004 taurus engine had correct 4 releif piston,the heads are different only where the water pump is driven and valve cover bolt holes.Both sets were roller follower rather than buckets and all internals are the same valves,springs,guides, locks and seals.it appears the chains and tensioners are the same and of course the rails,cams and gears are different.I have not yet assembled the engine back as i have had a hard time locating the o'rings for timing housing into the vvt and for the head.Mazda could not even look them up.I ordered some for a 07 ford fusion and they were extremely expensive 19.45 per ring(6 needed) and they could not service the housing seal to head(2 needed).i decided to look at jaguar and they serviced both part number large o'ring c2c8281 $.89 each and part number c2c8278 small o'ring $1.45 each for a grand total $8.30.i hope they are right when they come in i have my fingers crossed.
#26 (permalink) |
Hey, I just replaced my Mazda motor with an 07 Fusion motor. Everything went great, I took a lot of photos of disassembly and even made a cheeky little time-lapse of us putting the engine back in [https://www.facebook.com/photo.php?v=10151305093889155]. Thanks so much for your help on here guys!!
However, I am now looking to sell my Mazda engine block [118k w/blown head gasket]. Anybody on here interested or know where the best place to shift it would be? I can't seem to post in the classifieds here :-/ ![]() Here's a pic of it without the timing cover and valve covers. |
#27 (permalink) |
does anyone know of a bigger throttle body for my 05 6s that will bolt on and only needs to re learn the computer
#28 (permalink) |
Quoted: 11 Post(s)
I am helping a friend fix his 2003 Mazda 6, engine recently deceased. A few years back I swapped a 3.0 Taurus into my 1999 Contour SVT, so I was pleasantly suprised to see the Mazda 3.0 is a Duratec at heart. Local yard has a Mazda engine, but it is $1300. Fusion looks to be the way to go, cheaper and less miles. Just to clarify, the Taurus did not come with VVT but the 6 and Fusion both have it? If so, I will be sure to get the right engine for the swap. I don't feel like swapping heads and such.
Thanks for all the good info, have been reading a few threads on swaps, really helpful. |
#29 (permalink) | |
Quoted: 47 Post(s)
Good luck CR
2003 Mazda 6s MTX Mods - Yeah, I got some. ![]() My Threads: DIY Engine Replacement Track Car Prep My YouTube Channel for in-car track videos: http://www.youtube.com/user/canyonry...ow=grid&view=0 |
#30 (permalink) |
Quoted: 11 Post(s)
Canyon, thanks for the info. I began this adventure reading your posts, honored to have your comments. Going to pick up an '06 Fusion with 26K on it today for $500. Hoping it is a smooth swap. You still believe in dropping the engine and trans out of the bottom? All gaskets are Mazda 2003 spec?
Thanks again!
StL Dave 2008 A5 2005 Vette 1996 Ranger 1970 Camaro |
Advertisement | |
