Low Engine Temp - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 21 (permalink) Old 09-23-2011, 07:26 PM Thread Starter
SeeMeZoomZoom's Avatar
Low Engine Temp
So, I am getting the following CEL's: P0126 and P0128. I've checked the fluid temp and that is fine and the fan has been running. I pulled an engine diagnostic stat after the car had been running for a little bit and the engine temp is around 130 F. I am thinking the thermostat has gone bad and needs replaced but I wanted to get other opinions before I swap it out.
Thanks
2003 Mazda 6S
Dark Steel Metallic/Black
Aluminum gas cover, air box mod
2010 CX-9 GT AWD
Cooper Red Mica/Sand
Moonroof/Bose Package, Nav System, Roof Rack, Remote Engine Start, Class III Hidden Hitch, Softride hitch mounted 4 bike rack, and of course... a Buckeye Trailer Hitch Cover
SeeMeZoomZoom is offline
post #2 of 21 (permalink) Old 09-26-2011, 12:13 PM
banana boat.
flipper66's Avatar
Quoted: 329 Post(s)
either it is your T-stat, seal, or the CTS not reading properly.
replace T-stat and seal and see how it goes.
flipper66 is offline
The Following User Says Thank You to flipper66 For This Useful Post:
SeeMeZoomZoom (09-27-2011)
post #3 of 21 (permalink) Old 10-04-2011, 10:28 AM Thread Starter
So I replaced the t-stat this past weekend and it seemed to run fine on Sunday. Well the wife came home yesterday and said the CEL came back on. I pulled the code and it was P0128, Coolant Thermostat. I'm thinking maybe this time it is the Engine Coolant Temperature Sensor. Do anyone know where that is or could send me a pic from the service manual?
Thanks
2003 Mazda 6S
2010 CX-9 GT AWD
post #4 of 21 (permalink) Old 10-04-2011, 01:38 PM
banana boat.
flipper66's Avatar
Quoted: 329 Post(s)
it is under the TB on a black plastic tube.
The green and red 2 wire clip in the picture is the CTS.
post #5 of 21 (permalink) Old 10-04-2011, 02:40 PM Thread Starter
Thanks flipper. Is it possible to get to that without taking the 2 coolant tubes off? I am guessing not based on how tight it is in there. Is there anything else that would cause that CEL?
2003 Mazda 6S
2010 CX-9 GT AWD
post #6 of 21 (permalink) Old 10-04-2011, 10:09 PM
karlt10's Avatar
Quoted: 25 Post(s)
What did you use for a thermostat? If it doesn't have the secondary spring and shut-off valve, it won't work right. Doesn't allow coolant to mix or flow properly.
Same goes with O'Reilly's thermostat that has the secondary spring and shut-off valve; it doesn't work correctly either. It's too high of a temp- 192. Factory is 188.
I went rounds with both situations 4 weeks ago. I then put in the correct Motorcraft thermostat (RockAuto.com part RT1175) and everything has been fine since.
One interesting thing I discovered when I had the incorrect thermostat with no secondary spring and valve- the coolant DOES NOT completely/properly flow through the block. It was plain of day because of the different in color of the coolant.
Eibach springs / MazdaSpeed bars / Bilstein / Steeda Adj FR links / Racing Beat RR links / GTSpec Rear Susp & Trailing Braces / Steeda shock tower brace
EBC Ultimax rotors & pads / StopTech lines / Motul fluid
MSDS headers / Magnaflow cat / Racing Beat mufflers / Cork Sport urethane hangers / WeaponX coils / AER CAI / Fluidampr pulley
EGR mod / FilterMag / Street Unit engine mount /
B&M trans cooler / Amsoil fluid
Mazda iPod adapter
/ CX7 antenna
Continental Extreme DWS / Bridgestone Blizzak
karlt10 is offline
post #7 of 21 (permalink) Old 10-05-2011, 08:49 AM
banana boat.
flipper66's Avatar
Quoted: 329 Post(s)
I don't think there is enough space. either way the coolant needs to be drained as the sensor is inside the coolant track and will release any remaining fluid behind it
post #8 of 21 (permalink) Old 10-05-2011, 12:07 PM Thread Starter
I used the thermostat from O'Reilly's; Murray brand. The temperature is only getting to about 140 degrees with the new thermostat in there, so there is still something else going on. That's why I am thinking it is the CTS. Which I did notice that on Rockauto, there are two of them listed, and one in the wrong part. The CTS doesn't screw into the block like the cheaper one shows, it just slides into the hole.
2003 Mazda 6S
2010 CX-9 GT AWD
post #9 of 21 (permalink) Old 10-05-2011, 12:11 PM Thread Starter
There is enough space to get to it with the coolant hoses still attached. Last night I had to change out the air intake tube (that I broke while changing out the t-stat ) and I was looking where the CTS comes out. And yes coolant does spill out, all over the place, when you take the sensor out without draining it first. Looks like it is time to change out the coolant as well.
2003 Mazda 6S
2010 CX-9 GT AWD
post #10 of 21 (permalink) Old 10-06-2011, 08:49 PM
karlt10's Avatar
Quoted: 25 Post(s)
It could be you have an air bubble. If you don't have the factory manual, the coolant 'burb' procedures are a bit bizarre...
Fill the system - install the cap
Get the engine up to temp - wait until the fans come on
Rev the engine at 2500 RPM for 3 minutes
Then rev the engine at 3000 RPM for 1 minute
Let idle for 1 minute
Rev at 3000 RPM for 1 minute
Repeat "several times"
Let cool and if level has dropped, fill-up reservoir and repeat process.
Your cap could be bad and leaking pressure.
Mazda iPod adapter
/ CX7 antenna
karlt10 is offline
