Engine light code U0073 U0101 U0155 HELP - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 4 (permalink) Old 05-27-2011, 09:58 PM Thread Starter
What does each code stands for can someone help and what needs to be done?
Duocore is offline
post #2 of 4 (permalink) Old 05-27-2011, 10:09 PM
The Great NY's Avatar
Quoted: 37 Post(s)
Groans: 7
Groaned at 39 Times in 33 Posts
U0073 is a CAN bus communication error, U0155 is a communication error to the gauge cluster, U0101 is communication error to the TCM(transmission ecu)
i would just clear the codes and see if they come back. if it comes back then there may be a problem. possibly loose connection somewhere. double check the 10mm bolt on the ECU and make sure its tight(moreso snug)
Fully Built - Spoolin' and Juicin'
Flash Tuning For Your Mazda - Hit Me Up
The Great NY is offline
post #3 of 4 (permalink) Old 05-28-2011, 12:59 AM Thread Starter
Also my AT light is on ( light next to the high beam). What is that sorry im bad with cars. Also got another code P0174. I cant believe i just brought this car and so many problems with it already fml.
Duocore is offline
post #4 of 4 (permalink) Old 12-16-2014, 11:01 AM
2003 mazda 6
i HAVE 2 CODES ON A 2003 MAZDA 6
U0073 AND A U0101
CKD WIRING AND CONNECTIONS i SEE NOTHING
WHERE DO I GO I HAVE NEVER EXPERIENCED THESE CODES AND WOULD APPRECIATE A LITTLE HELP IN WHERE TO GO
Darrel is offline
