valve cover gasket and front cover gasket replacement - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Go Back   Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum > Technical / Performance / Model > Mazda 6 1st Generation (2002-2008) > Engine / Drivetrain > 3.0L V6
New User? Register
Old 01-13-2011, 05:19 PM   #1 (permalink)
Default valve cover gasket and front cover gasket replacement
2004 V6 Mazda 6 with 86k miles, is it normal for the valve cover and front cover gasket to start leaking? The dealer and an independent shop quote 10 hrs of labor for the front cover gasket, so it's definitely not a cheap fix. I'm taking the car to the independent shop tomorrow, he wants to see if it's really the valve and front cover gaskets are leaking. Just wondering if other Mazda 6 owners have run into this too. Thanks.
'12 6i Touring Plus
gnahc79 is offline   Reply With Quote
Old 01-14-2011, 04:13 AM   #2 (permalink)
Toadster's Avatar
Send a message via ICQ to Toadster Send a message via AIM to Toadster Send a message via MSN to Toadster Send a message via Yahoo to Toadster
um - 10 hours of labor for a valve cover gasket? are you sure you don't mean a head gasket?
SOLD 2004 Performance White MAZDA6s MTX
Injen CAI | Magnaflow Catback | CP-E MAF-c | 18% Tint | Red Line MT-90
17x7 Kosei T1 TS Wheels & Continental ContiExtreme Contact DWS 225/45-17
My Mazda6 PICS|Toadster's Website
Toadster is offline   Reply With Quote
Old 01-14-2011, 08:16 AM   #3 (permalink)
tkemme's Avatar
No, I think they mean the timing chain cover gasket on the "front" of the engine. Alldata.diy shows 3.5 hours to change both valve cover gaskets and 10.8 to change the timing chain(s) cover gasket. You actually have to drop the engine out to do it.
SUPERCHARGED 03 6s/07 engine/07 MTX, custom MSDS headers/Magnaflow 34106 cat, Exedy lightweight flywheel, ACT MZ023 heavy-duty pressure plate and ZM6-HDMM Modified Street disc, airbox mod, EGR mod, remote oil filter, (vac/boost, air/fuel ratio, fuel pressure gauges), AWR lower engine mount
tkemme is offline   Reply With Quote
Old 01-14-2011, 03:37 PM   #4 (permalink)
You got it. Is replacing the timing/front cover gasket part of normal maintenance in general for any car? 10+ hrs and dropping the engine seems a bit much, but if it needs to be done so be it.
'12 6i Touring Plus
Old 01-14-2011, 04:29 PM   #5 (permalink)
banana boat.
flipper66's Avatar
Quoted: 116 Post(s)
I have a lot more miles than you....... and never replaced any of those gaskets. I would consider going to a heavier weight oil or dinosaur oil before I spent the 900 bucks on labor to change the gasket.
Some people have great success with those stop leak agents that you pour on the CC that you can get at autozone.... for 8-10 bucks it might be worth a shot.
flipper66 is offline   Reply With Quote
Old 01-14-2011, 05:04 PM   #6 (permalink)
tkemme's Avatar
In my experience the answer is NO that is not normal. What did your independent mechanic say was leaking?
Old 01-14-2011, 05:23 PM   #7 (permalink)
The Great NY's Avatar
Groans: 7
Groaned at 39 Times in 33 Posts
10 hours is an ok qoute for both valve covers and a timing cover gasket. depending on where you go to have it done unless u do it yourself will dictate how much it will cost.
and the engine DOES NOT have to come out to remove the timing chain cover.
Punisher 6 - Twin Turbo - Noble Hybrid V6
"H.A.T.E.R.S- Having Anger Towards Everyone Reaching Success"
"FULLY BUILT AND SPOOLIN" -CLICK ME
FOR MAZDA 6i/6s TUNING & MAZDA6/SPEED6 TCS Auto-Off Module - PM Me for Info
The Great NY is offline   Reply With Quote
Old 01-14-2011, 06:50 PM   #8 (permalink)
The independent shop took a look and said timing cover is a very unlikely culprit. He said that there is a small amount of oil leaking from the oil pan gasket, should be replaced within the next 5-6 months or so. There's some oil buildup on the side of the oil pan near the exhaust, and a small amount of oil slightly higher. He thinks the oil that is up higher is most likely from air coming in and blowing it up a little higher, which would be why the dealer tech would say the timing cover gasket is leaking. I'm certain I am not repeating all of what he said 100% here .
VC gasket, barely any leak. There's some dirt buildup near the VC gasket but nothing close to requiring replacement.
No charge for the inspection too, my first time there. I'm definitely bring my car there for the oil pan gasket fix and any future major repairs.
'12 6i Touring Plus
