3.0L burning oil - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 20 (permalink) Old 05-04-2010, 11:25 AM Thread Starter
mwalker46's Avatar
Question 3.0L burning oil
hey guys, my car is burning a bit of oil, other than piston rings, valve stem seals, gaskets and the pvc what else can cause it to burn, compression is right on the money, plugs are dry as can be, replaced pcv valve twice to be sure, pulled valve covers off valve stem seals are great.. leak down test perfect, haven't checked my precats yet thats all thats left i think, i don't know what else can cause this.. any info would be awesome!! thanks
mwalker46 is offline
post #2 of 20 (permalink) Old 05-04-2010, 12:08 PM
tkemme's Avatar
Please define "a bit" of oil? Is she smokin like a pig or are you just a little low at oil change time?
tkemme is offline
post #3 of 20 (permalink) Old 05-04-2010, 01:39 PM
Quoted: 11 Post(s)
When I sold mine, I was putting half a liter in a week and I couldn't find any oil leaks at all. It only had 110,000km on it. Unfortunately, it was 10,000km over warranty.
2004 Mazda6 V6 GT GFX *SOLD*
- AEM Cold Air Intake, black housing headlights and taillights
wing_woo is offline
post #4 of 20 (permalink) Old 05-04-2010, 10:18 PM
Me too
mine smokes alot so i would like to know also
gbojon is offline
post #5 of 20 (permalink) Old 05-05-2010, 08:41 AM Thread Starter
mwalker46's Avatar
i have 91,000km's on it, burning maybe a little over a quart and a half or so... around there, its not smoking like a pig, it comes and goes, but when it smokes its just a puff here and there, not constant
post #6 of 20 (permalink) Old 05-05-2010, 11:47 AM
tkemme's Avatar
For trouble shooting I would go get a piece of clear or nearly clear plastic/rubber hose from Home Depot, Lowes or what ever your local building/plumbing supply store is and replace the PCV inlet tube that runs from just before the throttle body over to the front valve cover. Are you familar with how the PCV system works on our engine? With this in place you can easily see which way the air/oil vapor is flowing. The tube sould remain clean as air flows from the intake pipe down into the front valve cover. If you see oil vapor flow up from the valve cover back into the inlet, you have problems.
This is a great way to verify PCV valve operation. If you put a few drops of dark engine oil from the end of the dip stick into the end of the clear hose where it attaches just before the throttle body, it is easy to see which way and how fast the oil is being sucked. At idle it should be sucked very quickly down toward the valve cover. The flow should slow as the throttle valve is opened when you rev the engine. If the oil drops are blown back into the inlet at any point this is BAD!
tkemme is offline
post #7 of 20 (permalink) Old 05-05-2010, 01:13 PM Thread Starter
mwalker46's Avatar
ok, and if oil is going back into the inlet, what does this tell me? how do i fix it?
post #8 of 20 (permalink) Old 05-05-2010, 02:33 PM
tkemme's Avatar
If the flow is from the valve cover back into the intake (at any rpm) then either: your PCV valve is stuck closed and you have some degree of piston ring blow-by (the rate of flow tells you how bad), or your PCV valve is fine and you have massive ring blow-by which is more than the PCV valve can vent by itself. ANY BACK FLOW IS BAD! If the flow is slight and you find your PCV valve stuck closed, your lucky and you just need a new valve. In the other case something in your engine is toast. All these test should be done with the engine warmed up.
tkemme is offline
post #9 of 20 (permalink) Old 06-25-2012, 10:01 PM
My exhaust is pretty heavy also.
Definitely burning oil. Consuming quite a bit of oil. Maybe a quart a week.
Tsintsin-jingjing is offline
post #10 of 20 (permalink) Old 06-26-2012, 09:08 PM
I've never used any of those Stop Leak or No Smoke engine treatments ... but then again, I think I'm losing about half a quart of oil a day.
You think that stuff would work?
