Coil pack replacement. - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 8 (permalink) Old 05-01-2010, 05:23 AM Thread Starter
I'm going to be replacing the plugs on my 04 6s 3.0 with 85000 miles. My question is should I replace the coil packs while doing this. I haven't had any problems with the original ones but if I'm going to be taking them off to replace the plugs this would be the time to do it.
Where would be the best place to order oem coils if I do replace them.
hypergt is offline
post #2 of 8 (permalink) Old 05-01-2010, 07:17 PM
TalonTsi90's Avatar
Quoted: 39 Post(s)
Groans: 5
Groaned at 5 Times in 5 Posts
You dont need to replace them that often. Only when they go bad.
2006 6 Hatch Grand Touring 5spd Sunroof
TalonTsi90 is offline
post #3 of 8 (permalink) Old 05-05-2010, 01:55 PM
Send a message via AIM to xorifrafox Send a message via Yahoo to xorifrafox
I have seen reference to "coils" and "coil packs" is there a difference?
xorifrafox is offline
post #4 of 8 (permalink) Old 05-05-2010, 05:24 PM
TalonTsi90's Avatar
Quoted: 39 Post(s)
Groans: 5
Yes, and no. Coil refers to a singular unit, usually combined with a distributor cap and rotor button to distrbute the spark to the plugs. Coil pack usually has more than one per unit, usually on a 4 cyl that utilizes batch firing (fires more than one cyl at a time). For a coil-on-plug ignition like on the 6, we have 6 single coils that are fired by the ECU to ignite the plug it sits on top of.
The Following User Says Thank You to TalonTsi90 For This Useful Post:
xorifrafox (05-06-2010)
post #5 of 8 (permalink) Old 05-06-2010, 10:03 AM
e4w
e4w's Avatar
Quoted: 32 Post(s)
Send a message via Yahoo to e4w
My tight budget is pushing me toward Oreilly Auto Parts for their coils which are $45 Each. But i'm wondering if i could buy three for now for the back three spark slugs since they would be the hardest to get to and keep the stock front three until they go bad, but replacing all six spark plugs with no prob
[B][SIZE=2]2004 6s MTX/sport clutch/air box mod/de badged/ TB Coolant by-pass /6000K HID/AWR 88D Rear mount/AWR 88D upper trans mount/exh mod
my 6
185.66hp/ 170tq 11/2011
213kmi (Sept 4, 2016) update
e4w is offline
post #6 of 8 (permalink) Old 05-06-2010, 12:24 PM
TalonTsi90's Avatar
Quoted: 39 Post(s)
Groans: 5
If they arent bad, dont replace them. Its not necessary....
post #7 of 8 (permalink) Old 05-06-2010, 07:29 PM
e4w
e4w's Avatar
Quoted: 32 Post(s)
i just heard they go bad and mine been on since the car was new..present mileage 96,000+i'll be needing headers too since the cats go bad as well
my 6
e4w is offline
post #8 of 8 (permalink) Old 05-06-2010, 08:08 PM
TalonTsi90's Avatar
Quoted: 39 Post(s)
Groans: 5
My wifes Lincoln is a 98, and only had one go bad due to some leakage that we never found the source of, and never occurred since. It has 8 at $70 a pop...
Since i havent looked at ours yet, do these cars come with manifolds or headers from the factory? I would think replacing the cat with a new one, or a test pipe would be much cheaper.
