Need Help p0171, p0174 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 7 (permalink) Old 04-14-2010, 06:47 PM Thread Starter
ok my girlfriend has a 03 mazda6 with the 3.0v6 this code started about a month ago i have reset it twice but it came back within a day the car is 100% stock no intake no exhaust and if it was just the light i wouldnt care but the car bucks at idle while in gear at stop lights but as soon as you give it gas it runs fine need to know what to replace to fix this she wants to take it to the stealership even after the last time she took it there i had to fix it when it came out
03dodge is offline
post #2 of 7 (permalink) Old 04-18-2010, 10:45 PM
twowheelin's Avatar
Both codes are indicating a too lean condition on the front and rear cylinder banks. Basically there is extra air coming into the engine that isn't getting measured. This could be caused by a dirty MAF sensor which is supposed to measure the amount of incoming air. It could also be a loose or cracked vacuum hose somewhere inboard of the the MAF that is letting extra air in. (That isn't measured...)
Welcome to 6Club!!
Hawk ceramic pads, SS lines, PowerSlot Rotors, Tanabe-NFs+Konis, Kosei K1-TS, Spin On Conversion,
, 2 1/4" Exhaust,
, Adjustable Fan Controller
(An
twowheelin is offline
post #3 of 7 (permalink) Old 04-19-2010, 10:10 AM Thread Starter
thanks it was the pcv hose on the firewall side of the engine
03dodge is offline
post #4 of 7 (permalink) Old 05-06-2010, 03:19 PM
jayrx7trbo2's Avatar
I need to look for that.. I have the same issue but it also hestates under full throttl, wonder if i have a air leak.. It would be great if its thats simple
jayrx7trbo2 is offline
post #5 of 7 (permalink) Old 06-18-2012, 10:43 PM
I have the same problem, i did find that PCV hose was cracked. So i replaced it and PCV valve at the same time. Contacted local mazda and was told that check engine light will go away right away. But it haven't yet, i even drove 50+ miles (as i was told) to reset comp. Anyone have any suggestions how to reset it quicker. I did stop by autozone and got reading for 2 codes (0171, 0174) both Low fuel pressure, large vacuum leak, dirty MAF, ect.
gray03 is offline
post #6 of 7 (permalink) Old 06-23-2012, 12:08 PM
HerronScott's Avatar
Quoted: 148 Post(s)
Have Autozone reset it.
Scott
HerronScott is offline
post #7 of 7 (permalink) Old 10-11-2012, 12:50 PM
Or disconnect battery...
dropt09 is offline
