Torque Specs for motor mounts? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 1 (permalink) Old 04-08-2010, 05:02 PM Thread Starter
Quoted: 4 Post(s)
Groans: 5
Hello, I just finished installing my AWR mounts (love em after a "breaking in" drive from PDX to Seattle and back were CRAZY loud during break in, dont let it scare you away from these things! they do settle down!)
but I couldnt find any torque specs for the bolts (eneded up sheering the last one torquing to 70lbs, but was an easy fix)
So I was seeing if anyone has the specs they used while installing their mounts? Thanks in advance!!
06 M6 V6 | AWR 88 duro mounts | CAI | Oil Catch Can | MSDS Header | Magnaflow High flow cat | Custom 2.5" Exhaust with Dual Flow-Pro mufflers | Exedy stage 1 clutch | Exedy racing flywheel | 17" Toyo Proxes4 | 50 watt 6000k HID High Beam | 50 watt 5000k HID Low Beam | Silverstar turns | DICE aux ipod mod | All LED retro | De-badged front and rear | shaved | 35% tint gauged at 22% | Scangauge II |
06m6v6 is offline
