AWR rear engine mount install - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 12 (permalink) Old 03-06-2010, 11:25 AM Thread Starter
tkemme's Avatar
I just installed my new AWR (Anthony Woodford Racing) rear lower engine mount. I searched the forum and didn't see anything about it, so thought I'd post some pics. I payed $105 + $11.04 shipping. The install is on an 03 6s with manual transmission, (the engine is actually an 07). The machining and fit up are excellent. It looks so good I clear-coated it with clear Rustoleum enamel to keep it looking good. It has 70 durometer urathane bushings.
To get the old one out you remove the 3 bolts attaching the front of it to the transmission. (Be careful, the bottom of the engine may want to swing forwards or backwards when you remove the bolts.) Then remove the rear bolt that goes through the subframe mount. This was the hardest one for me because of corrosion. Then you need to swing the bottom of the engine as far forward as possible and push/lift the mount up out of the aligning yokes in the subframe mount. Installation is the reverse process.
ID:	74254   Click image for larger version
ID:	74255   Click image for larger version
ID:	74263   Click image for larger version
ID:	74264   Click image for larger version
tkemme is offline
post #2 of 12 (permalink) Old 03-06-2010, 08:03 PM
mariusvt's Avatar
Quoted: 6 Post(s)
I actually just put this in myself thursday. Long story short I had a cpe 70 duro for ~1.5 years, then stock for a while and now AWR 70 duro. The AWR wishbone mount blows the CPE wishbone out of the water.
2013 Mustang 6MT
2007 T-Gray 6s MT
, traded
2008 Phantom Blue Mica 3s Hatch - AT
, Stock
mariusvt is offline
post #3 of 12 (permalink) Old 03-08-2010, 11:35 PM
mortikia07's Avatar
you have some serious rust problems.
NGK Sparkplugs, EGR Mod, Custom-intake, custom 3' exhaust, S-Tech Springs, Ruff Racing 18" wheels with 215/40/18 nangkan ns2 tires, pulstar Platinum spark plugs ,metra kit , 600k xenon hid, XDVDN8190N touchscreen.
mortikia07 is offline
post #4 of 12 (permalink) Old 03-09-2010, 12:03 AM
Egierda's Avatar
Quoted: 11 Post(s)
It's a good idea to support the tranny with a jack before removing the mount. If you've got OEM upper mounts, then you're damn right that it's going to move when you remove the wishbone! I'm surprised that you lined it back up without jacking it.
04' 6s MTX sedan
- SOLD
Egierda is offline
post #5 of 12 (permalink) Old 03-09-2010, 08:00 PM Thread Starter
tkemme's Avatar
The rust is not nearly as bad as it looks in the pics, but yeah say hello to Michigan winters and road salt. I plan to clean this up and repaint it as soon as it warms up.
tkemme is offline
post #6 of 12 (permalink) Old 03-09-2010, 08:08 PM Thread Starter
tkemme's Avatar
You are correct. I am fortunate in that I still have a section of exhaust pipe out and I could easily swing the motor with one hand. It took me longer to take the pictures than to install the part.
tkemme is offline
post #7 of 12 (permalink) Old 03-12-2010, 05:13 PM
PDX6's Avatar
Send a message via AIM to PDX6 Send a message via MSN to PDX6 Send a message via Yahoo to PDX6
how is the vibration with the 70 duro? I just got the 88 and when I start it, as it is turning over for the first time it feels like I just started a diesel tractor and idle is very rumbley (like it was about to die) turn on the AC and it doubles.
'06 tungsten 6s
Straight Pipes w/magnaflow tips, 35%tint, black out badge, shaved door guard, K&N fliter with gutted airbox, resonator delete and custom open fog besel
PDX6 is offline
post #8 of 12 (permalink) Old 03-15-2010, 06:10 PM Thread Starter
tkemme's Avatar
The 70 durometer seems very smooth. I haven't road tested it yet because I am still finishing up some other stuff, but at idle and rev-up I really like it.
tkemme is offline
post #9 of 12 (permalink) Old 03-17-2010, 04:11 PM
PDX6's Avatar
I drove to the coast over the past few days (couple hundred miles) and the 88 duro mount has broken in nicely. Some vibration at stops but no where near as bad as new and cold. Enough so that I just ordered the rest of the mounts in 88 from AWR
'06 tungsten 6s
PDX6 is offline
post #10 of 12 (permalink) Old 05-09-2010, 05:09 AM
Groans: 10
Groaned at 4 Times in 4 Posts
I recently got under my car to replace the factory rear motor mount, with the CPE one. My motor was swaying and banging around in the engine compartment, same noise etc it made when i replaced the first factory mount with a new factory mount.
Upon getting under the car i come to find my mount is in perfect condition, but the Bracket that it bolts to on the sub-frame, had broken off. I am unsure of exactly how to fix this, I'm going to take it to a muffler shop and see if they can "re-weld" the bracket onto the sub-frame, but am a bit worried it will happen again.
Any advice on this? Will a "re-weld work or is there another fix or an ideas from the community out there?
FYI: i am a spirited driver but not extreme.
Used03M6s is offline
