Go Back   Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum > Technical / Performance / Model > Mazda6 1st Generation (2002-2008) > Engine / Drivetrain > 3.0L V6
Old 10-28-2009, 11:30 AM   #1 (permalink)
I'm experiencing a minor oil leak/drip with my 2005 Mazda 6s (3L V6, MTX). The leak is minor enough that no oil is leaking onto the ground but it is leaking enough to have a drop occationally land on the exhaust which results in an oil burning smell. I thought the leak might have been a bad crank seal (harmonic balancer seal), but after replacing that seal I still have a leak. It almost seems like the leak is coming from somewhere above where the crank seal is located. Are there any known oil leak issues with this car so I have a starting point to start my search?
2005 Mazda 6s
Manual Transmission
Injen Cold Air Intake
CP-E MAF Customizer
bullion is offline   Reply With Quote
Old 10-28-2009, 11:45 AM   #2 (permalink)
Egierda's Avatar
There are three seals which have a tendency to go on our motors.
1) Rear main seal
2) Oil pan gasket
3) Front crank seal
I just had the exact same issue as you and needed to replace the oil pan gasket. My rear main seal is also letting a few drips out but it's not bad enough to warrant tearing the transmission out to replace.
Check your oil pan gasket on the passenger side for signs of leakage.
04' 6s MTX sedan - Tein - TC Sportline - Seibon - AEM - Magnaflow - Cusco - Streetglow - Momo - iRotors - Hawk Performance - Maxcar - Ignited - Exile - American Bass - Legacy - TenzoR - Falken - Redline - TWM - Compustar - Racing Beat - AWR - Autometer - Lotek - AutoExe - Megan - Feather Carbon - Autolumination - Wedge Engineering - Scroth - Sparco - Sabelt - NRG - DG Motorsports - Carbon Creations - Cordova Motorsports - Sniper Tuning - Axxess - GT Spec - Tanabe - CP-E - Scangauge - Steeda - Hella - Aero Catch - ELF Racing - Stoptech - Car_LED - ARP - Project Kics
Egierda is offline   Reply With Quote
