please help me.
I have a 2006 6 3.0 with just under 60K miles. A few weeks ago it started cutting out once the fuel tank falls below 1/4. I have tried searching for help with this but I have not found anything. There are so many things to check with this, fuel filter, fuel pump, water in fuel, etc. I am just wondering if anyone else has had this problem with this and knows where to start. Thanks B
briang97603 Klamath Falls Oregon "The race is long.. but in the end, it is only with yourself." ~unknown. |
#2 (permalink) | |
QUOTE (briang97603 @ Oct 18 2009, 12:05 AM)
might be just a gauge problem, zero out your trip meter after fill up. If you get 300 miles with still 1/4 tank on average city/freeway it might be a gauge problem assuming you get about 21 mpg. just my two cents
2004 MAZDA 6S 5 DOOR HATCHBACK,STEEL GRAY, ATX KNN CAI, MAGNAFLOW EXHAUST TRUECOOL LPD TRANNY COOLER EVOKE 17X7 GUN METAL RIMS, 225/45/17 ZR NEXEN N3000 TIRES |
I also have an '06 V6. I also have the same problem. I don't think that anyone on here has found a fix. I only have 9,500 miles on my car. I think it's a problem with the fuel pump module design.
The only thing that people have said to do is to change the fuel filter. I haven't done that yet because I have my doubts that it will do anything. The fuel pump is obviously sucking in air and not getting fuel. Just park on an incline with less than 1/4 tank. Listen to the car by the rear seat bottom. You will hear a muffled popcorn popper type sound. That is your fuel pump sucking up air. I'm going to dig into this problem further but not 'til spring. I'll be sure to post my findings. Do what I do until then... Treat the 1/4 tank mark as empty. BTW, I got the crap scared out of me a couple months ago. I was on a freeway onramp. Uphill at WOT. It surged VIOLENTLY. Not good. That's why I want to figure this out. BP
'06 6s 6-speed ATX - Lapis Blue - bought it in Dec '08 with 4100 miles on it. LOL! '96 Ford Contour 2.0L Zetec MTX - my project car I normally live on the CEG |
The fuel filter is built into the fuel pump and can be cleaned but not replaced. Personally this is where I would start since it's a free fix.
thanks for the suggestions, i will look into the fuel filter and see if i can do anything with that. i am sorry to hear that others have the same issue, but at the same time i am relieved. at least now i know it is not just my car.
thanks for the help.
I am going to take a good look at this problem over the weekend. Any other suggestions of ideas I should look at with this issue while I am tinkering?
#7 (permalink) |
I have the same problem.
I have a 2005 6S 5door AT. About a year ago I first noticed the problem. Before this started I had driven the car down to the 'E' with no problems. Now - if I get at or below the last hash mark before the 'E' on the gauge I will start sucking air in the pickup (you can hear it if you have the radio muted/off), especially on moderate cornering or hard acceleration. When I get to this point and fill up the most I have been able to fill is 15 gal. so I know that the gauge is not bad. I record trip miles and fill gal. every time I fill up and my mileage is pretty consistent, just can't drive more than about 340 miles before needing to fill (avg. ~24 m/g). I have just been monitoring my gas gauge and try to make sure I fill before I get to that last hash mark. A couple of weeks ago I was getting low on gas and before I could fill up I got a cel. I tried my old OBD scanner but it wouldn't work on the Mazda. So I just got a new scan tool that will work with the CAN interface and pulled these codes: P0455, P0442, P2187, P2189, P2197. The P04xx codes have to do with Evap.system leaks, the P218x codes have to do with Lean/Rich issues and the P2197 seems to be geared to the O2 sensors. Since there is air picked up in the gas line I can see where it could think there was lean problem - try to compensate - then gets full fuel flow and goes rich. I have finally cleared the cel and will see if it returns soon. Not being familiar with the structure of the filter, pickup, pump assembly I am not anxious to drop the tank and pull things apart to see what the issue is. Since I have 79K+ miles I am well out of warranty and dread the thought of what the dealer would charge for repairs. It would be great to hear if anyone comes up with a specific diagnosis of exactly what the problem is. |
#8 (permalink) | |
QUOTE (copper 6 5 door @ Oct 31 2009, 11:36 PM)
Concerning the fuel pickup issue - does anyone have a diagram of the in-tank components and has anybody seen information on removing/replacing gas tank in the Mazda 6?? |
#9 (permalink) |
Bump for this. I'm having the same issue.
k Today I was driving in second gear and gave it the berries and when the rpms hit about 5k and it violently "cut out". Like a fuel cut, or a huge miss. Deffinetly not a easy feeling. |
