check engine code P0442 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 4 (permalink) Old 08-15-2009, 02:07 PM Thread Starter
This code just came up on my 03 and I was wondering if anyone else has came acrossed this. If so, what should I be checking and where should I be checking?
20hawkins03dm is offline
post #2 of 4 (permalink) Old 08-15-2009, 04:48 PM
make sure your gas cap is on tightly- clear the code- disconnect the battery and see if it comes back. it may take a while. if it comes back you you need to check all vacuum lines/hoses in your evap emissions system for cracking -dryrottong- etc. a small leak is kinda hard to find on your own. the dealers usually have a smoke machine to find difficult leaks. my 03' 6s light came on last week with the same code. i think it was a loose gas cap.
jiminEcricket is offline
post #3 of 4 (permalink) Old 08-16-2009, 07:21 PM Thread Starter
QUOTE (jiminEcricket @ Aug 15 2009, 02:48 PM)
make sure your gas cap is on tightly- clear the code- disconnect the battery and see if it comes back. it may take a while. if it comes back you you need to check all vacuum lines/hoses in your evap emissions system for cracking -dryrottong- etc. a small leak is kinda hard to find on your own. the dealers usually have a smoke machine to find difficult leaks. my 03' 6s light came on last week with the same code. i think it was a loose gas cap.[/b]
That what I have been looking at. I have cleared the code but haven't had the chance to drive it to see if it would come back. Thanks. Let me know what you find out.
post #4 of 4 (permalink) Old 08-20-2009, 08:32 PM
[quote]
have been driving the car (well, my wife has) and up till now no check engine light. so it seems it was the loose gas cap. hope your fix is this simple
