BACKGROUND:
POWERMOD PRO SEQUENTIAL ADVANCED ENGINE MANAGEMENT COMPUTER: stands apart from most other piggy back computers because fuel mixture is modified by intercepting the actual fuel injector pulse signal, not by modifying Airflow meter or MAP sensor signals. This method enables engines with larger size injectors, even low resistance injectors, to be tuned with ease. the standback from CPE does just the opposite of this and messes with the airflow meter Fuel can be modified +/-100% and ignition timing up to +/-50 degrees totally independent of each other at any engine speed or load. An on board 22psi boost MAP sensor ensures correct tune even if the original engine sensors have been ‘saturated’ or reached their maximum reading. The unique design ensures a quick and easy tune with predictable and consistent results. Tuning is performed in Real Time using Windows based software. Advantages: All existing features of the car will be retained Interceptor can be easily removed, returning to original system. Can control larger capacity HIGH or LOW resistance injectors (with low resistance injector driver option) Built in turbo OVER BOOST fuel-cut eliminator Ideal for applications such as low boost supercharging,/turbo charging and modifying naturally aspirated engines Real-timing tuning. No uploading of entire tunes and waiting for programming. Custom tune your engine - why be limited to a choice of pre-programmed tunes? Easy and fast tuning - less dyno time needed Tuning: Ignition timing and fuel mixture changes are totally independent. Tune Fuel Mapping to any required air/fuel ratio. Adjust fuel flow by –100% to +100%. Alter Ignition Timing to any required value by advancing or retarding up to 50 degrees Tune using Manifold Pressure (inbuilt +22PSI MAP or external GM 3 Bar) or Throttle Position Powerful Engine DATALOGGER is a standard feature EASY to use PC software allows all settings to be programmed in 'real-time'. Each Fuel, Ignition and Stand-alone Map is constructed of 17 load points, every 500rpm, up to 10,000 rpm. Helpful software tuning tools include: Engine load and rpm history indicator Quick key to jump to current engine load Separate Fuel and Ignition trim Warning indicator when fuel injector duty cycle is nearing 100% Quick copy of load points to entire column or row Datalogger: Comprehensive display of real time and logged engine data parameters allowing analysis of: Air/Fuel ratio Fuel injector duty cycle and opening duration Mass Airflow Meter and Manifold Absolute Pressure voltages Engine tachometer Throttle Position Sensor Manifold pressure Optional Extras: Internal +22 PSI MAP Sensor External 3 Bar GM MAP Sensor Launch Control 3 auxiliary function outputs can be used for: Nitrous (wet system) control Nitrous (dry system) control with additional fuel mapping RPM activated solenoid control Gear change shift light Intercooler spray Extra fuel pump enable Generic output if the above is not suitable Built in electronic Boost Controller (solenoid required - factory solenoid can be used if equipped) INTERESTED AND CAN MAKE THE PURCHASE IN THE NEXT MONTH OR SO: 1. mazda6smtx (PAID) 2. shaun6s (PAID) 3. nc4spd (PAID) 4. 5. 6. 7. 8. 9. 10. ok, for those who expressed interest in getting this now. i will now be taking payments. as soon as i get the payments from everyone, the order will be placed. all buyers will be updated as i get shipping info. they will get sent to me, then to the buyer. price is $710 shipped please remit payment to: justinw@twistedvisionz-carclub.com include your screen name, and year of your 6 and shipping address if its different than paypals one.
Punisher 6 - Twin Turbo - 305whp, 303wtq @ 6.5psi - HATE IT OR LOVE IT, THIS IS JUST THE TIP OF THE ICEBERG "Nuthin To Prove, Just Watch Me Groove" ![]() COME OUT AND REP YOUR 6 FAMILY!!!!
How many wires need to be cut/tapped for this tuner?
Wagner Header'd! and enjoying it! Wants to punch bullydog in the testicules |
#3 (permalink) | |
QUOTE (ShaDrag @ Aug 3 2009, 02:43 PM)
15 or so IIRC that most of them off the top of my head
Is it worth it for normally aspirated engines? i.e more horsepower!
2003 Mazda 6s- Konis all around, Progress Rear Sway, Hid in Lows, EBC Ultimax Sport Rotos w/ EBC Redstuffs, PIAA 1000XT's, 225/45/17 Toyo Proxes 4's and Ecsta's, Cntinental Extreme Contitacts, MSDS headers w/Magnaflow spun metallic cat w/stock exhaust |
![]() Join Date: Jul 2006
I will buy this. Not until spring though. Should be closing on the house soon with the baby on the way. So add me as you like. Round 1 if its a way off or on round 2 or 3.
when are you doing the buy because i really want in on it but cant until about the 14th? what computer requirements are there?
#7 (permalink) | |||
QUOTE (chilimax21 @ Aug 3 2009, 11:26 PM)
QUOTE (USAF 6S @ Aug 3 2009, 11:32 PM) Quote:
QUOTE (nc4spd @ Aug 4 2009, 05:37 PM) Quote:
computer requirements, is your basic windows xp laptop. from what ive heard vista has a couple issues. you will need a serial port or usb to serial adapter to hook to the tuner.
#8 (permalink) |
ok we now have 5 orders to place the first order. one person has experssed they wont be able to pay till next week so i will let this ride till next week. and will get everything in order
edit: sorry we lost on, back down to four
#10 (permalink) |
