Dog Bone Engine mount options?? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 13 (permalink) Old 04-15-2009, 02:03 PM Thread Starter
Archplsm's Avatar
Quoted: 19 Post(s)
Send a message via AIM to Archplsm
Does anyone have the CPE lower engine mount installed on a 3.0l? If so, how bad is the vibration increase. Where would the vibration increase fall between an OEM mount and a Urathane mount. I use my car as an every day driver and don't want too much increase in vibration. I have had urathane mounts before and could not stand how much increase there was in vibrations. If CPE is too much increase is there another one someone would suggest other than OEM?
Archplsm is offline
post #2 of 13 (permalink) Old 04-15-2009, 02:28 PM
Quoted: 68 Post(s)
Groans: 13
Groaned at 6 Times in 6 Posts
QUOTE (Archplsm @ Apr 15 2009, 01:03 PM)
Does anyone have the CPE lower engine mount installed on a 3.0l? If so, how bad is the vibration increase. Where would the vibration increase fall between an OEM mount and a Urathane mount. I use my car as an every day driver and don't want too much increase in vibration. I have had urathane mounts before and could not stand how much increase there was in vibrations. If CPE is too much increase is there another one someone would suggest other than OEM?[/b]
If you don't want any vibrations, get the AWR or StreetUnit in a lower durometer.
xtmesisx is offline
post #3 of 13 (permalink) Old 04-15-2009, 03:55 PM
dfw6er's Avatar
QUOTE (xtmesisx @ Apr 15 2009, 12:28 PM)
If you don't want any vibrations, get the AWR or StreetUnit in a lower durometer.[/b]
You'll still get more in cabin vibration with the lower durometer SU mount compared to the stock mount, trust me. But it's nothing to worry about, either....the increased vibrations are only noticible if you're really trying to think about it.
dfw6er is offline
post #4 of 13 (permalink) Old 04-15-2009, 10:49 PM
ive never noticed a vibration increase... then again i have headers, it makes the car shift and respond better
04 v6 MTX - 238.8 WHP (w obx headers) - 17" Enkei RS+M rims with Goodyear Eagle 215/45. Performance Mods: AEM CAI, Magnaflow Mufflers w/ customized exhaust, CP-E Headers, Apexi SAFC II, optimized throttle body, Racing Beat Rear Sway Bar, EGR Mod, component polk system with a 12" sub and alpine amps, 7k HID headlights, DDE's, and more. All self installed! check out my
and my
To come: optimizing exhaust WTB: steel grey eyelids
hot6onaplatter is offline
post #5 of 13 (permalink) Old 04-15-2009, 10:56 PM
USAF 6S's Avatar
+1 to the above posts. You have to pay a bit to play a bit. The CPe mount wont shake your lug nuts loose. But you do feel it. Now when I got into the side engine mounts is when I noticed a definitive change in the characteristic of my 6 at idle.
2006 DC 6S Sport MTX
USAF 6S is offline
post #6 of 13 (permalink) Old 04-16-2009, 01:26 AM
Front 1ine's Avatar
Groans: 8
Groaned at 7 Times in 7 Posts
QUOTE (USAF 6S @ Apr 15 2009, 05:56 PM)
+1 to the above posts. You have to pay a bit to play a bit. The CPe mount wont shake your lug nuts loose. But you do feel it. Now when I got into the side engine mounts is when I noticed a definitive change in the characteristic of my 6 at idle.[/b]
Is that b/c the stock side mount is filled with liquid to reduce vibrations and the AWR one is just metal?
206 WHP / 192 WTQ
Front 1ine is offline
post #7 of 13 (permalink) Old 04-16-2009, 09:17 AM Thread Starter
Archplsm's Avatar
Quoted: 19 Post(s)
So it sounds like the order of options regarding vibration and stiffness for response are:
OEM (sloppy but low on vibrations)
StreetUnit (a little stiffer, but has a lower 62 durometer to address vibrations)
CPE (middle of the line durometer at 70, sounds like a noticeable vibration increase but not obnoxious)
AWR (urethane bushings, this will give the most rigid response, but a significant increase in vibration)
Archplsm is offline
post #8 of 13 (permalink) Old 04-16-2009, 02:15 PM
akhilleus's Avatar
CPE hands down. The urethane transfers a lot more vibration into the cabin. I have the 70duro CPE wishbone, and a AWR 70duro urethane tranny mount, and I notice the AWR mount vibration, but the CPE is not even noticable, and wasnt so much even b4 the tranny mount.
Another thing you should consider is that the CP-E is made out of EPDM rubber, and this stuff is the best! It has the heat resistance and elasticity of rubber, with the hardness of urethane. Personally, I hate urethane mounts, since they can easily get dirty or dry, and can make popping and creaking noises. Urethane also has a different memory, so it can get distorted after awhile. Once that happens the noises will only get worse and you will have more movement. It also seems to be worse in the cold and rain.
I had wanted to get a bushing manufacturer to make EPDM bushing replacements for the AWR mounts and the suspension. Not much interest from the manufacturers, and it costs $700 for a mold.
Go with CP-E, you will not be disappointed.
<span style="color:#000080">SOLD: 2003 Lapis 6s, ATX: Racing Beat - KYB - Enkei - CP-E - Moog - AWR - Hawk - EBC - Redline - K&N - Stant - NGK - CWest - TW</span>
akhilleus is offline
post #9 of 13 (permalink) Old 04-17-2009, 04:40 AM
Administrator
Mazda Gremlyn's Avatar
I'll tell you after this weekend when i finally install mine... only been 2 years since I noticed the thing was torn!
2004 Mazda6s MTX: Gone...
Mazda Gremlyn is offline
post #10 of 13 (permalink) Old 04-17-2009, 07:54 PM
USAF 6S's Avatar
QUOTE (Mazda Gremlyn @ Apr 17 2009, 03:40 AM)
I'll tell you after this weekend when i finally install mine... only been 2 years since I noticed the thing was torn![/b]
2 years ....
USAF 6S is offline
