A/C not working - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 6 (permalink) Old 03-26-2009, 08:54 PM Thread Starter
i just installed a K&N cold air intake and new headers and exhaust and for some reason now my air conditioning doesn"t work.... the light turns on saying that its blowing a/c but the compressor never turns on and the air is the same temp as outside air, it blows air just fine and the heater works but no cooling of the air. i was wondering if maybe since i unhooked the battery for the work if maybe there is some sort of reset that you have to do? don't know what to do but i live in the south and it's about to get hot so if anyone has any suggestions please let me know!!!!
Thanks
littlenuke4all is offline
post #2 of 6 (permalink) Old 03-27-2009, 12:46 AM
KCV6's Avatar
No reset required. I would be checking the wire going to the AC cluch coil (the plug on the AC compressor). when off there should be 0Vdc in the pin, when on there should be 12Vdc present. If this is good then the compressor is toast (well the coil is). If there is no 12Vdc, check the AC fuse and relay. If all is good then the climate control and fan control is not working properly.
Cheers...... Mark
03 6 I4 classic hatch
07 6 MPS
I HAVE NO FRIENDS BUT MY CARS DON'T CARE
KCV6 is offline
post #3 of 6 (permalink) Old 03-28-2009, 01:41 AM
take it in for service the new fuse will cost ya $1 plus the obnoxious diagnostic fee
04 v6 MTX - 238.8 WHP (w obx headers) - 17" Enkei RS+M rims with Goodyear Eagle 215/45. Performance Mods: AEM CAI, Magnaflow Mufflers w/ customized exhaust, CP-E Headers, Apexi SAFC II, optimized throttle body, Racing Beat Rear Sway Bar, EGR Mod, component polk system with a 12" sub and alpine amps, 7k HID headlights, DDE's, and more. All self installed! check out my
and my
To come: optimizing exhaust WTB: steel grey eyelids
hot6onaplatter is offline
post #4 of 6 (permalink) Old 03-28-2009, 02:11 AM Thread Starter
QUOTE (hot6onaplatter @ Mar 28 2009, 12:41 AM)
take it in for service the new fuse will cost ya $1 plus the obnoxious diagnostic fee[/b]
i checked all of the fuses though... all of the fuses and relays are good, the indications inside all say that everything is working, i had the freon checked and it's good, and i ran a wire straight from the battery to the compressor and it turned on and worked fine..... it's just that for some reason it's not getting the power signal when it should and i had a mechanic look at it and he was stumped... he even hooked up his computer to my car and ran a check on it and nothing came up to cause an issue..... i really don't want to take it to a mazda dealer cuz i know they're going to charge me an arm and a leg so if there could be any other reason you guys can think of please let me know
Thanks
post #5 of 6 (permalink) Old 03-28-2009, 02:29 AM
if you checked the wire going to the compressor and you have no voltage check where the pressure switch is if thats unplugged or maybe the wiring is sitting against the header the ac control head wont activate the compressor clutch
rtsvtec2004 is offline
post #6 of 6 (permalink) Old 03-29-2009, 02:08 PM
there are many hidden fuses (not in the fuse box), im not sure if you know where they are but yeah thats my bet
and my
