OCV gone bad! - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 6 (permalink) Old 02-07-2008, 06:07 PM Thread Starter
My OCV has gone up in my 2004 Mazda6. The dealer told me it would be $650 parts and labor to replace the OCV, but the part was on national backorder. So I paid for the part and a week later they tell me the part arrived so I setup an appointment.
Well I get a call the next day that the part was upgraded and it is now an assembly of parts (2 OCV and timing guides). I now need to get both OCV valves replaced and the timing guides. My price is now $2,314.00 to replace. Called Mazda and they tell me that since I have 85,000 miles on my car that they can't do anything for me. She said that 85,000 miles is a lot on a car, but I told her that it wasn't a lot for a good car. Seems to me that if the part needed to be upgraded that there was a problem with the original part . Apparently they don't even make the original OCV and it is sold out worldwide. I tried junk yards, etc., but no luck. Any suggestions?
hogrocket is offline
post #2 of 6 (permalink) Old 02-08-2008, 03:02 PM
twowheelin's Avatar
Could you explain what an OCV is, and maybe why you need a new one? What happens when an OCV goes up?
Hawk ceramic pads, SS lines, PowerSlot Rotors, Tanabe-NFs+Konis, Kosei K1-TS, Spin On Conversion,
, 2 1/4" Exhaust,
, Adjustable Fan Controller
(An
twowheelin is offline
post #3 of 6 (permalink) Old 02-08-2008, 03:22 PM
djquik1's Avatar
Groans: 14
Groaned at 9 Times in 6 Posts
Well I get a call the next day that the part was upgraded and it is now an assembly of parts (2 OCV and timing guides). I now need to get both OCV valves replaced and the timing guides. My price is now $2,314.00 to replace. Called Mazda and they tell me that since I have 85,000 miles on my car that they can't do anything for me. She said that 85,000 miles is a lot on a car, but I told her that it wasn't a lot for a good car. Seems to me that if the part needed to be upgraded that there was a problem with the original part . Apparently they don't even make the original OCV and it is sold out worldwide. I tried junk yards, etc., but no luck. Any suggestions?[/b]
I work for Mazda and am very curious as to what an OCV is and what it does?I would be happy to help direct you as to what you should do,but I need a little more information.
2010 F-150
1990 F-150
djquik1 is offline
post #4 of 6 (permalink) Old 02-08-2008, 03:25 PM Thread Starter
Could you explain what an OCV is, and maybe why you need a new one? What happens when an OCV goes up?[/b]
Pulled this from Mazda6Tech...
Mazda uses a static camshaft, however the shaft is attached to a cog that can advance or retard its rotation. The valves can open sooner or later, but never longer, faster, or higher. The cog is controlled by a precision oil pump, called the oil control valve (OCV). The car's computer tells the OCV how much to advance or retard the intake timing based on a number of input parameters, such as pedal pressure, engine temp, and more.
post #5 of 6 (permalink) Old 02-08-2008, 03:28 PM
djquik1's Avatar
Groans: 14
So you need the VVT controller assy?PM me your VIN.And I will look into it for you on parts availibility.
2010 F-150
1990 F-150
djquik1 is offline
post #6 of 6 (permalink) Old 02-08-2008, 03:35 PM Thread Starter
So you need the VVT controller assy?PM me your VIN.And I will look into it for you on parts availibility.[/b]
PM sent.
