Serpentine Belt Routing - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 18 (permalink) Old 07-07-2006, 06:13 PM Thread Starter
Atlec's Avatar
Thumbs up
I thought I could remember where it was and how to put it back on, but I've taken off the serpentine belt and now i'm not sure how to route it back on there. Does anyone have a belt routing diagram?
I've tried to search for one and have come up empty handed. Thanks guys!
FireFox ~ <span style=\'color:Navy\'>Take back the web! </span>
Atlec is offline
post #2 of 18 (permalink) Old 07-07-2006, 06:21 PM
Revenant's Avatar
Send a message via AIM to Revenant Send a message via MSN to Revenant Send a message via Yahoo to Revenant
this help?
<div align="center">07 Mazda3s Black Mica
-+- Road Magnet -+- 5Zigen -+- F2 -+- Nitto -+- SilviaParts -+- Redline Tuning -+- RPM -+- GT Spec -+- Xenon Expert -+- Eneos -+-
03 Mazda6s Performance White
-+- Eibach -+- MagnaFlow -+- XTec -+- 5Zigen -+- ACT -+- Mazdaspeed -+- EBC -+- Kartboy -+- Optima -+-
Revenant is offline
post #3 of 18 (permalink) Old 07-07-2006, 06:27 PM Thread Starter
Atlec's Avatar
Thanks so much!
Atlec is offline
post #4 of 18 (permalink) Old 07-07-2006, 06:38 PM
Revenant's Avatar
Np.
Revenant is offline
post #5 of 18 (permalink) Old 08-24-2006, 10:29 AM
Send a message via Yahoo to bbruce65
I need to change mine on a 3.0 V6. Are there any tricks or suggestions to make the the change easier? Doesn't look like tehre is much room to manuver. Any tips would be appreciated!
bbruce65 is offline
post #6 of 18 (permalink) Old 08-24-2006, 11:05 AM
Having two people makes it so much easier. Get underneath the car and use a long 1/2" breaker bar on the tensioner (pull down towards you). There's a little lip under the car (can't remember exactly where, but you'll know when you're under the car) that you can wedge the breaker bar under to hold tension on the pulley. Then it's a piece of cake. Have the other person run the belt up top while you do the work on bottom.
<span style="color:black">'04 6s MTX
Mods: Yes.</span>
trickdout6 is offline
post #7 of 18 (permalink) Old 08-28-2006, 08:53 AM
Thanks for the advice. I will ask a friend of mine to help.
bbruce65 is offline
post #8 of 18 (permalink) Old 08-29-2006, 05:47 PM
How often should the serpentine belt be replaced?
2004 Mazda 6s MTX
fly757 is offline
post #9 of 18 (permalink) Old 10-09-2006, 10:30 AM
hey guys, my question: doesn't the belt loop through the tensioner pulley and its mounting location on the block? If so how do you get the belt out without removing the tensioner?
Maybe there is a relief in tensioner pulley and the belt can slide off but I can't see it.
can anyone verify how simple and how much time it would take?
Sassafras is offline
post #10 of 18 (permalink) Old 12-26-2008, 01:46 AM
QUOTE (Sassafras @ Oct 9 2006, 06:30 AM)
can anyone verify how simple and how much time it would take?[/b]
Hello - I just replaced both the serpentine and water pump belts on my 2004 6s. trickdout6 had great advice and hopefully I can add to it. Space is tight with the main belt and wiggling the belt around the tensioner is the biggest challenge I had. We had to hold the tensioner open while we moved the new belt into place. To gain access, we also came from underneath and removed the plastic panels in the wheel well
What caused me to change the belts was excessive noise after 65k.
twig is offline
