6s (V6) PCV Valve Failure, Excessive Oil Consumpti - Page 21 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 4Likes
post #201 of 358 (permalink) Old 07-19-2010, 02:29 PM
DoubleD's Avatar
^^ I've got cat failures as well, we have no emissions testing where I live so I'm not concerned at all about that. I'll keep you posted when I change the PCV.
2004 Mazda 6S 5 door Luxury Package Steel Gray Metallic
DoubleD is offline
post #202 of 358 (permalink) Old 07-24-2010, 08:54 AM
Ericzoom's Avatar
I figure at 36k miles on my 04' 6s, it's time to replace the PCV valve.
Went to Autozone and picked up the PCV#1001. Part fit perfectly, took me 15 minutes tops.
Cheap preventive maintenance.
04' 6S ATX cooler,airbox mod
Ericzoom is offline
post #203 of 358 (permalink) Old 08-02-2010, 08:12 PM
So who is gonna (or already done) a DIY project to replace the stock POS PCV valve?
I just went to AZ, got the wrong part (someone else here already had the same thing happen - PCV1001 - same bottom/wrong top). Went to PB, dealer part only. Went to one dealer, not stocked (seriously?) and 16.99. Went to another dealer, in stock, right part, *wrong* price (24.24).
I ended up ordering from RockAuto for 13.58 shipped. What a joke.
If the bottom of the valve wasn't such a specialty fitting, it would be easy to hook up a metal check valve up to some generic tubing, no?
2005 M6s wagon 5spd.
2005 - Wagon - Sport - Manual - Squall Blue
mmr159 is offline
post #204 of 358 (permalink) Old 08-02-2010, 09:29 PM
After re-thinking, and re-reading post #48, it seems pretty simple. Why replace the complicated part/connection when a failed valve effectively is an open/open circuit? For more assurance it could be drilled out... though it might be tough to do without leaving shrapnel in there.
Anyway, I'm pretty set on adding a cheap, but effective second valve. Could someone point me to 84fordman's original writeup? The link is broke. I'd like to get the appropriate gear and stop the bleeding (of M1).
mmr159 is offline
post #205 of 358 (permalink) Old 08-11-2010, 07:09 PM
Found the correct link...
Install An Inline PCV Valve (Prevent engine failure) - International Mazda Forums
Also: I've replaced the OEM valve with a factory (Airtex / Wells) valve. So far, and I could be getting ahead of myself (100 miles), it appears that I'm still losing oil. One thing to note about the valve was that it wasn't very "check-ish". I could blow through both ends almost as much as the old one I was replacing.
mmr159 is offline
post #206 of 358 (permalink) Old 08-23-2010, 01:40 AM
fullyarmed101's Avatar
Groaned at 18 Times in 17 Posts
I hope you get that fixed soon... Keep us updated if you found the real problem and what the fix was...
2005 Mazda 6s MTX Lapis Blue
VISIT
fullyarmed101 is offline
post #207 of 358 (permalink) Old 09-21-2010, 07:06 PM
Can someone confirm correct Purolator PCV valve part # for a 2004 Mazda 6s, with 3.0 V6? Thanks. Also, I assume directions are the same for replacing as shown on the 2005, on page 20?
mjabjornson is offline
post #208 of 358 (permalink) Old 09-23-2010, 06:41 PM
zazoomster's Avatar
Send a message via Skype™ to zazoomster
White Smoke Every Time I start the Engine.
Originally Posted by crossbow View Post
Who:
This CRP is specifically for the Mazda 6s (V6) platform.
PCV
The PCV (Positive Crankcase Ventilation) Valve is a check valve that allows excess exhaust fumes in the crank case to re-enter the intake manifold and be re-combusted for emissions sake.
Problem:
If the valve breaks (its basically plastic), one of two things can happen,
http://forum.mazda6tech.com/viewtopic.php?p=36503#36503
1: The valve gets stuck close. Pressure builds up in the crankcase, eventually finding an outlet. This usually results in oil spraying back up into the intake tract, or blowing the dipstick out of its holder.
2: The valve gets stuck open. When vaccuum is applied (application of throttle), the intake air sucks the oil out of the crankcase using the pcv hose as a large straw.
Problem 2:
If option 2 occurs, a low oil condition can occur, which has an extremely high likelyhood of spinning a bearing. This can result in just a rod bearing replacement, or a complete bottom end rebuild. ($$$ and Very Bad)
Identifying The Problem:
Weekly oil checks will reveal a sudden increase in oil consumption. Sometimes blue smoke exiting the exhaust can be indicative of oil being sucked into the intake tract of the engine (and being burned in the combustion chamber).
This is exactly what is happening to my '04 Mazda 6s. Just over 72,500 miles, it started blowing out white smoke at start-up. I had my oil changed twice; once at an autoshop, and once at a Mazda Dealer (as the dealer stated the autoshop over filled it by 2 qts).
That was this past Monday. Now, every time I start after sitting for a few hours, it blows out the white smoke. My whole car was filled with smoke this afternoon... almost like a burnout.
But I only see smoke at start up. There was oil in my intake tube, which I cleaned once already.
I'll definitely check the PCV. I hope this will solve my issue.
Thanks,
jsGMan
'04 Mazda 6s * Spyder Projector Lights * Magnaflow Catback * Cordova TB * Steeda TBS * K&N Typhoon CAI * Tanabe Strut Tower Brace * Powerstop Brakes * Goodyear TripleTred Tires * PIAA Courtesy Lights * Sylvania LEDriving Lights * ABS Grille * SickSpeed Horns * Shark Fin Antenna * Hyperflash Taillight LED Bulbs * REMIN Dashkit * Hood Dampers * Evil M * Tinted Windows
zazoomster is offline
post #209 of 358 (permalink) Old 09-24-2010, 04:20 PM
zazoomster's Avatar
Mazda Stock #
None of my local Auto Parts stores, including NAPA carries this. I had to go to a dealer.
Dealer Part # AJ 0313 890B ~ $24.92. You can buy online for about 1/2 that.
post #210 of 358 (permalink) Old 09-24-2010, 04:58 PM
Ericzoom's Avatar
Typical dealer ripoff.
I paid 6 bucks at Autozone.
Ericzoom is offline
