Honestly, just burn it the rest of the way. In this case put it out of its misery with fire...
IIRC one of the main harness bundles goes right underneath the center console. Its likely that your main wiring harness is fried, and if there was power on while this happened then major shorts could have happened further causing damage. I seriously want to see pictures and know how this happened though...
yeah i wish it just burnt all the way. it must have smothered itself out with the windows up.
i really cant say how it happened...
after it happened i only had airbag light flashing and traction control, dsc light on. it drove fine.
i then vacuumed the shit out, then it lit up like a christmas tree. the air bag light went solid, no speedo, abs, check engine and tps lights on to. it feels like its in limp mode now. no manaul shift mode either
i already got new console. going to install that, then prolly ship off to mazda to work on the spaghetti. if i can keep it under $500 ill be happy
I'll be honest thay is going to be an expensive fix. @SonicNutrition can confirm but I think the harness are all one piece and not easily fixable. good luck.
i know its no going to be a easy fix.... to fix it right.
i am sure the harness is one piece.
i can turn a wrench, im the first person to do 2v 4.6 to 5.4 in a new body fly-by-wire f150. it is the only one in exsistance. its on cardomain and youtube. also had a blown fox and 95 cobra.
anyway, i snipped some wires. some went to the aux and 12v outlet and some went to black control box i assume is for the airbags. then i went to the fuse box in cabin. second one i checked was blown. 5 amp for SAS?. swapped that out and bingo. half the lights went out. back to only traction control and dsc lights. the airbag lights out now but engine lights still on. its out of limp mode. got to get my reader and run codes.
so next step is to call junkyard and see if they can cut a chunk out of the main harness under cup holders. there is only like 6 more wires that run down to under drivers seat. should not be that bad to solder in. even if i leave it as is, i think i can live with no TC and driver seat airbags. so far im only 89.99 deep for the center console and its the upgraded shiney plastic one.
Hey, my car is great fun, more so than my old six, though I miss my old subwoofer.
Anyway, my point is, your signature, you need to put that image on photobucket or something. You're trying to embed a picture from your storage device and that doesn't work.
so i got the console in. very easy.
still need seat cover and ebrake handle cover.
got haynes manual in. factory repair manual on disk in transit.
skimming through i found disclaimer about the tcs/dsc/abs system and wiring harness.
basically it says: do not repair the harness in any way b/c it may change resistance values and screw the whole system up. i should take a pic of disclaimer. i guess we will see what happens after i hack her up.
It probably wont work right. A lot of the car is dependent on can bus and very low voltages, there is a chance you could be fine but probably a greater chance for issues. I would recommend soldering with a good silver solder to try and minimize extra resistance. Good luck..
