2018 Mazda 6 turbo - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 11 (permalink) Old 05-26-2018, 05:44 PM Thread Starter
an63lvegas's Avatar
Quoted: 21 Post(s)
2018 Mazda 6 turbo
wanted to ask if anyone has any info on what turbo make/model our 2018 Mazda 6s use?up to what HP/psi could the turbo handle?
an63lvegas is offline
post #2 of 11 (permalink) Old 06-15-2018, 12:55 AM
macranger's Avatar
Following. I'm curious how the Dynamic Pressure Turbo system will respond to modifications.
2018 Mazda 6 GT 2.5T
2011 Mazda 3 2.0L
2008 Mazda 3 2.3L
macranger is offline
post #3 of 11 (permalink) Old 07-09-2018, 12:42 PM Thread Starter
an63lvegas's Avatar
Quoted: 21 Post(s)
never got a response the car does react good to mods in term of power but I am having issues with the engine getting hot.
post #4 of 11 (permalink) Old 07-09-2018, 01:10 PM
ocramida's Avatar
Quoted: 213 Post(s)
Interesting, Savagegeese mentioned a "hot" engine bay in his review, not sure if it was alluding to a hotter running engine. He was reviewing a stock car, so of stock was "hot" then it stands to reason that an increase in power may cause heat issues.
2016 Mazda 6 iGT Meteor Gray w/Tech ("I'm Batman!)
ocramida is online now
post #5 of 11 (permalink) Old 07-09-2018, 01:59 PM Thread Starter
an63lvegas's Avatar
Quoted: 21 Post(s)
when normal driving here in Vegas heat engine stays at 210F but when i start WOT a few runs I have gotten it about 230F and get display message "engine out put limited" but luckily it quickly cools back down to 210F once i let off the throttle,What would you guys say could help with these issue?Upgraded Radiator,Intercooler,different coolant?
post #6 of 11 (permalink) Old 07-09-2018, 07:38 PM
Dougspeed's Avatar
Quoted: 45 Post(s)
I was looking at the 16+ CX-9 forums since they basically have the same turbo motor that's in our cars, and one guy just replaced his exhaust with a free flowing aftermarket one. He hooked up his obd scan tool with the engine running before and after the modification to measure any differences. It apparently recorded cooler engine exhaust temperatures after installing the exhaust. So that's maybe one thing you can look at doing.
Dougspeed is offline
post #7 of 11 (permalink) Old 07-09-2018, 09:51 PM
ocramida's Avatar
Quoted: 213 Post(s)
Is this stock?
post #8 of 11 (permalink) Old 07-10-2018, 09:19 AM Thread Starter
an63lvegas's Avatar
Quoted: 21 Post(s)
@ocramida just 3" catback spits 2.5" and have tried it stock tune and with 2 different tunes that im working with at the moment
post #9 of 11 (permalink) Old 07-10-2018, 09:39 AM
jman1200's Avatar
Quoted: 57 Post(s)
I am not a tuning expert but I do own a tuned SHO.
When tuned, the thermostat is usually replaced with one that runs 10 to 20 F colder. When you buy a tuning kit it usually comes with the pressure map sensor, thermostat and new gaped spark plugs (and the tuner).
Who is doing your tunes?
jman1200 is offline
post #10 of 11 (permalink) Old 07-10-2018, 06:49 PM
Dougspeed's Avatar
Quoted: 45 Post(s)
Did you feel any increase in power with the new exhaust on the stock tune when it's running at normal temps?
