changing Thermostat - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Go Back   Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum > Technical / Performance / Model > Mazda 6 1st Generation (2002-2008) > Engine / Drivetrain > 2.3L I-4
New User? Register
Old 01-16-2013, 10:16 PM   #1 (permalink)
Default changing Thermostat
hey guys i need to change my thermostat. i already bout a new one but cant figure out on how to get to the old one. anyone have a good write up on this or point me in the right direction so i can get this changed out soon. any help or advice is thanked!
2004 Red Mazda 6 i4
Red04 6 is offline   Reply With Quote
Old 01-16-2013, 10:22 PM   #2 (permalink)
Smoke Screen
Mr.Smoke's Avatar
Groaned at 4 Times in 4 Posts
Quoted: 668 Post(s)
V6 or i4?
Mr.Smoke is offline   Reply With Quote
Old 01-16-2013, 11:10 PM   #3 (permalink)
sorry should have said that! its a i4
2004 Red Mazda 6 i4
Old 01-16-2013, 11:18 PM   #4 (permalink)
Smoke Screen
Mr.Smoke's Avatar
Quoted: 668 Post(s)
Check out this thread. Some links in there might help ya out.
How to change thermostat
Old 01-17-2013, 07:48 AM   #5 (permalink)
sweet! thanks man!
2004 Red Mazda 6 i4
Old 01-20-2013, 11:57 AM   #6 (permalink)
I just did mine this past week. 2005 i4 Mazda 6. And this is my take on changing the thermostat.
1- remove Neg battery cable
2- loosen Pass front wheel
3- jack up car and remove wheel
4- remove plastic inner splash guard over control arm
5- release tension on serpentine belt and loosen belt from power steering pulley
6- locate PS pump on top of Pass side of motor and remove 3 bolts(lower bolt is a strain to get to with lines attached((and pull toward fender))
7- locate T-stat housing below PS and loosen Radiator hose clamps to drain fluid from housing
8- loosen 3 bolts on T-stat housing itself (lower bolt is a strain to get to)
9- replace T-stat (i used my finger to lubricate gasket before install)
10- reinstall all parts in reverse order
Some folks said to run the engine with HEAT on for some amount of time.
I personally burped the hoses, by squeezing them to force any air out of the lines. Then added coolant to system until it stopped forcing bubbles out radiator opening. (This will help to make sure Heater is blowing warm air and not cold air.
slatta is offline   Reply With Quote
Old 01-20-2013, 01:22 PM   #7 (permalink)
Final Impact's Avatar
Quoted: 194 Post(s)
Why are you changing it? Not that we want you to miss this experience, but what tell tail signs say its bad?
>79,000
Old 01-22-2013, 09:04 PM   #8 (permalink)
Quoted: 194 Post(s)
Engine coolant temperature (ECT) sensor
ECT circuit low input (P0117)
• The PCM monitors the ECT sensor signal at PCM terminal 1M. If the PCM detected ECT sensor voltage of 0.20 V or below, the PCM determines that the ECT sensor circuit has a malfunction.
ECT circuit high input (P0118)
• The PCM monitors the ECT sensor signal at PCM terminal 1M. If the PCM detected ECT sensor voltage of 4.58 V or above, the PCM determines that the ECT sensor circuit has a malfunction.
Thermostat
Coolant thermostat stuck open (P0126)
• If the ECT signal never exceeds 71 °C {160 °F} after the engine runs for a certain period, the PCM determines that the coolant thermostat is stuck open.
MONITORING CONDITIONS
— IAT: –10 °C {14 °F} or above
— Difference between ECT at engine start and minimum IAT: 6 °C {43 °F} or below
— Vehicle speed: 6.3 km/h {3.9 mph} or above Coolant thermostat stuck open (P0128)
• The PCM monitors MAF, IAT, VSS and ECT signals and calculates radiator heat radiation ratio while the following monitoring conditions are met. If calculated value exceeds threshold, the PCM determines that the coolant thermostat is stuck open.
— ECT at engine start: 36 °C {97 °F} or below
— Vehicle speed: 9.5 km/h {5.9 mph} or above
JMD902
>79,000
Last edited by Final Impact; 01-28-2013 at 05:24 PM. Reason: added search tag JMD902
Old 01-28-2013, 01:03 PM   #9 (permalink)
Changed it this weekend! Thanks all for the info and advice!!!
2004 Red Mazda 6 i4
