MAJOR issue methinks...20 miles of rattling and no start now... - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Go Back   Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum > Technical / Performance / Model > Mazda 6 1st Generation (2002-2008) > Engine / Drivetrain > 2.3L I-4
New User? Register
Old 12-27-2012, 12:06 PM   #1 (permalink)
Default MAJOR issue methinks...20 miles of rattling and no start now...
So yeah, I think I'm in for some major repairs, but seeing if the community can help me think of what it might be so I know how much to brace myself (and how much whiskey I need to have on hand)...
2007 Mazda 6i 2.3L 4-cyl. 90k miles.
In the past 5-6 months or so, I've had that strange ticking that happens just around 2.5k RPMs, but my mechanically inclined friends and family have advised me that it's not a bad tick, nothing to worry about.
I recently went on a 120-mile drive to a family Christmas party and noticed the ticking getting more noticeable, and a broader stretch of RPMs to create the noise. Then, about 20 miles out, major knocking. To me, sounded like misaligned lifters and/or piston knock, but there was a noticeable grinding sound too, not too loud, I had to have the hood open with the car running in park to hear it. Kinda sandpaper-y sound.
My mechanic relatives heard the knocking and started guessing what it might be...rod knock, piston knock, lifter misalignment, etc., and then I turned the car off and went back to the party. 3 hours later when I tried to start it up (and take it to a nearby mechanic shop), it started, the knock persisted, then my car stopped running. Tried the key again, and I got what sounded like a little bit of cranking then nothing.
I expect the worst, and hope for only some small minor issue. 90k miles is a drop in the bucket for a 2007 car, and I assumed this engine would have more life in it. I've been good about oil changes, and never had any Check Engine lights, low oil, or anything. I think the only awry thing was at about 50k miles when the coolant levels were low.
Any guesses? Anyone experience the same thing? Any advice would be appreciated....
~Mo
mobaar is offline   Reply With Quote
Old 12-27-2012, 12:24 PM   #2 (permalink)
Groans: 12
Quoted: 261 Post(s)
What is your oil level at right now?
xkreedx is online now   Reply With Quote
Old 12-27-2012, 12:48 PM   #3 (permalink)
Slate6's Avatar
Groans: 5
Groaned at 36 Times in 26 Posts
Quoted: 70 Post(s)
Similar thing happened to a friend of mine. He blew a rod right thru the block.
My Build Thread
http://forum.mazda6club.com/picture-...ld-thread.html
Slate6 is offline   Reply With Quote
Old 12-27-2012, 01:12 PM   #4 (permalink)
My best guess would be a spun rod bearing. I also would like to know what the oil level is right now. Same thing happened to mine at 98000 miles.
Tomi
Furytom is offline   Reply With Quote
Old 12-27-2012, 03:12 PM   #5 (permalink)
Checked the oil right after I arrived. Level was good (actually a tad high) and looked clear, not cloudy at all. I'm only a month out from my last oil change.
~Mo
Old 01-02-2013, 06:53 PM   #6 (permalink)
UPDATE:
Was able to get the car towed to a shop, and they were able to get it to start. Rod knock, piston grinding ("It quite obviously is the engine trying to freeze") led to a damaged engine, needing full replacement a la ~$5000 new, ~$3000 used. Too much considering the resale value on a 90k 2007 6 is only around $5500.
I loved my Mazda very much but total engine failure on a well-maintained car at 90k miles has left me wanting. I plan to call Mazda up tomorrow to voice my disappointment (not that I expect them to do anything).
I appreciate the input you've provided. Something tells me I won't be in the Mazda 6 club anymore...
~Mo
Old 01-03-2013, 01:16 AM   #7 (permalink)
Final Impact's Avatar
Quoted: 194 Post(s)
That's too bad to hear. Good luck in what ever path you take.
What model and locale are you from? $5500 ~ OUCH!!!!!
>79,000
Final Impact is online now   Reply With Quote
Old 01-03-2013, 10:37 AM   #8 (permalink)
legacy4life's Avatar
Quoted: 142 Post(s)
Sorry to hear about that. Also with so few miles too. Are you the only owner? Premature failure at that few of miles seems odd.
Smoke Side Markers | Sport Bumper LED Fog Lights | DDM Premium Slimeline HID Kit | NextMod Custom Molded BR Lip| NextMod AE Front Grille |Taillight Tint|Magnaflow Cat-back Exhaust | XCAR Link MP3/Bluetooth Kit| PAC-Audio Amp Amplifier Adapter | Carbon Fiber Stubby Antenna | Alpine MRP-M500 Class D Amp | Alpine Type R SWR-1240D | 18inch Montegi FF 15 |
legacy4life is online now   Reply With Quote
Old 01-03-2013, 12:37 PM   #9 (permalink)
Thats too bad man.
But I know the feeling, I had the same issue with mine at 98000 miles. It was well maintained as well.
I replaced my engine myself and it runs well for now.
I was also asking the local dealer what they would/could do about it. The answer was " well with almost 100K miles on it that sure can happen"
Thats when I left. I dont think I want another Mazda after my 6 is gone.
Good luck finding a solution with yours!
Tomi
Old 01-07-2013, 02:06 AM   #10 (permalink)
Quoted: 8 Post(s)
You could probably pull the engine and rebuild it for ALOT less. Depends on if there is any damage to the walls.
Cavalier2000 is offline   Reply With Quote
