*New Here* I am in some TROUBLE! 2004 Mazda 6i - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Go Back   Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum > Technical / Performance / Model > Mazda 6 1st Generation (2002-2008) > Engine / Drivetrain > 2.3L I-4
New User? Register
Old 01-02-2013, 01:38 PM   #21 (permalink)
AyB88's Avatar
To reset ECU, unplug the battery for roughly about 10 minutes, and step on your brakes for a few minutes, that way it'll clear out any left over electricity in your system. Go through all your connections, make sure they are dry. Follow Final Impacts directions.
Good luck man!
AyB88 is offline   Reply With Quote
Old 01-09-2013, 08:23 PM   #22 (permalink)
well its been a few weeks and everything is good besides random stalls when taking off from stops. I can drive on the highway forever and it be fine but as soon as I come to a stop and take off 50% of the time it will stall, sometimes die and sometimes just jerk the hell out of me. I know its not me doing this because before washing the motor it never done it. So I am just confused and lost.
hcokiid is offline   Reply With Quote
Old 01-10-2013, 05:37 PM   #23 (permalink)
Anyone?!?
Old 01-17-2013, 01:14 AM   #24 (permalink)
Originally Posted by Final Impact View Post
Be warned that that little misfire over time will cost you money by killing the CAT.
You really need to pull all the connections apart and clean and dry them. Soap and water, couple cans of compressed air to blow dry, and some dielectric grease applied liberally to keep the water out. Don't apply it over fungus or corrosion. It won't stop work in progress.
Find where the oil is leaking from. Some only leak at speed and the oil hits the ground never touching the car so its not apparent it has a leak. Althoguh it could be burning it. What have the OCI's been?
Edit - 2nd the shitty coil!
Killing the cat might save him money
cricket45auto is offline   Reply With Quote
Old 01-17-2013, 01:48 AM   #25 (permalink)
Try checking out your 1st 02 sensor maybe it got wet and is on the way out. You say that it jerks from a stop but works fine at constant speed msybe a/f ratios goin crazy. Also check all fuses at kick panels in cabin, as well as the ones in the engine bay next to the battery
Old 01-27-2013, 08:26 PM   #26 (permalink)
Sean486's Avatar
Quoted: 13 Post(s)
Have you read the codes yet?
'05 Mazda 6 iSport 187K Charcoal
'06 Mazda 5 69K Blue (sold, needed more room)
'92 Subaru SVX Lsi 157K Liquid Silver
'07 Honda Odyssey EXL 56K
Sean486 is offline   Reply With Quote
