04 6i has Loud valve train noise at 2800 RPMS and timing issues - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Go Back   Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum > Technical / Performance / Model > Mazda 6 1st Generation (2002-2008) > Engine / Drivetrain > 2.3L I-4
New User? Register
Old 12-14-2012, 05:43 PM   #1 (permalink)
Default 04 6i has Loud valve train noise at 2800 RPMS and timing issues with Video
So my Mazda6 spun a bearing. I replaced the block and assembled everything. The car ran great for 6 miles until I took the RPMs up to 3k+ and then the check engine light came on and the car died. CEL was for timing being too advanced. I tow it home and pop off the valve cover. Somehow the timing was a little off on the intake cam. I set it right, the car idles perfectly and runs...but everytime I rev it to 2800+ rpms, there is a loud buzzing in the top of the motor. I replaced the OCV and it made no difference. Also, I did get a retarded timing code. I am too scared to drive it down the road since I don't trust it now. It is hard to imagine the intake cam going bad for no reason...Any ideas?? I hope this sounds familiar to someone, because I hate to just throw parts at it.
I might be able to get a video of the noise later
GringoEJS is offline   Reply With Quote
Old 12-15-2012, 06:28 PM   #2 (permalink)
Final Impact's Avatar
Quoted: 194 Post(s)
You might want to do a static check on the OCV. It controls the advance/retard and can be removed and checked with a 12v battery. You can verify it opens fully and closes fully. If it was reused from sludge motor, it could be sticking. don't let your search vary but enter this; mazdaserviceinfo 1866-1U-05H its the OEM FSM for the L3 2.3. It'll walk you through how to set and adjust the cam timing and check the OCV.
Details please; was the whole engine replaced or did you place your head on a used block? What components were transfered from old to new?
>79,000
Old 01-14-2013, 04:03 AM   #3 (permalink)
I finally took a video of it, although looking back at the video, it doesn't show the obvious difference in sound at around 2800-3000 RPMs. I put a used block in the car, and swapped everything over from the top. I have done this swap 4 or 5 times now without a hitch until this. The OCV was actually swapped for a brand new one, but it didn't make a difference.
Old 01-14-2013, 11:15 AM   #4 (permalink)
Quoted: 194 Post(s)
The way it starts its as if the intake is over advanced OR WAY retarded. So if you swapped heads you had to time the Camshafts using the Alignment Timing Tool 303-465. Did you install NEW friction washers and how did you actually set the cam timing?
By the book, a dial indicator for TDC on #1 , and then tool Camshaft Alignment Timing Tool 303-465. Although there are ways around that tool, its just the easy thing to do by dropping it on. Take a look at this thread and and the pdf link inside.
TSB 2006 2.0 2.3 Crank Shaft bolt and timing pdf link
>79,000
xkreedx (01-14-2013)
