Idleing problem - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Go Back   Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum > Technical / Performance / Model > Mazda 6 1st Generation (2002-2008) > Engine / Drivetrain > 2.3L I-4
New User? Register
Old 11-19-2012, 08:16 PM   #1 (permalink)
Default Idleing problem
So my 2005 mazda 6 (2.3) Just started giving me problems while idleing but not while driving.. it started right after I did my first full fill up on it after it had gotten VERY low on gas:P might somone know what's going on?
cashmash123 is offline   Reply With Quote
Old 11-19-2012, 09:08 PM   #2 (permalink)
6Y MAZDA's Avatar
Groaned at 8 Times in 7 Posts
Quoted: 177 Post(s)
literally no one will know whats going on since you provided 0 details. "having problems" is so generic. for all we know, there could be 2 squirrels having sex in your engine bay and that is the problem....
2006 BCM MS6 GT #00584
CP-E 3" Straight Pipe Exhaust. CP-E TMIC. CS SRI/TIP. SU RMM. SU TP. Forge V1 BPV. Cobb AP. RichTuned. Denso ITV22. PTP HPFP Internals. STi S204 Lip. Megan Racing Springs. GenPu MS3 Wheels. VEI Boost Gauge. Blox Shift Knob. VG Shark Fin. 35W 8000K DDM HID lows/3000k fogs. Super White LED Tag Lights, Parking Lights, Interior Lights.
SOLD: 2009 Mazda 6i GT. Comet Gray Mica. 6-speed MT.
6Y MAZDA is offline   Reply With Quote
Old 11-19-2012, 09:28 PM   #3 (permalink)
I'm sorry! Okay so when it idles it will randomly drop to like 200 rpm then come right back up and that's the only time it gives me problems.
Old 11-20-2012, 02:21 AM   #4 (permalink)
Jordan6i's Avatar
Make shur you battery ground is tight, clean your maf sensor.
Jordan6i is offline   Reply With Quote
Old 11-20-2012, 08:11 AM   #5 (permalink)
Groans: 12
Quoted: 259 Post(s)
Sounds like a vac leak.
tapatalking.. err wait.
xkreedx is online now   Reply With Quote
Old 11-20-2012, 02:16 PM   #6 (permalink)
Final Impact's Avatar
Quoted: 194 Post(s)
Based upon the info: water is heavier than fuel and settles to the tanks bottom. Either being low OR the NEW fuel has water in it which doesn't burn well. It could have sucked up that water and other debris from the tanks bottom which is effecting the idle and you don't notice this at higher RPMs.
Because our oxygenated fuels inherently pull in moisture (methanol attracts water), I'd suggest some fuel treatment aimed at removing water. Fill it full and go for long drive on twisted road to get the water to mix and burn.
FWIW: every 4 months or so dump a bottle of Chevron Techron in there to clean the fuel system up.
>79,000
Old 11-21-2012, 12:26 AM   #7 (permalink)
I had the same issue with low Idleing....It was a vac leak ( small hose nearest the fire wall center...Hope it helps
lcervntes is offline   Reply With Quote
