got code p0171 little help needed - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Go Back   Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum > Technical / Performance / Model > Mazda 6 1st Generation (2002-2008) > Engine / Drivetrain > 2.3L I-4
New User? Register
Old 11-07-2012, 10:03 PM   #11 (permalink)
austinairport's Avatar
Groans: 42
Quoted: 4 Post(s)
That's pretty wild man. Do you have the workshop manual for our car?
MAZDA 6 FULL WORKSHOP MANUAL!!!!!!
Follow the link in that thread. Hopefully that will help you figure this out.
2004 Mazda 6i ATX -Ksport - Magnaflow - Motegi -
austinairport is offline   Reply With Quote
Old 11-08-2012, 01:26 AM   #12 (permalink)
it looks like i don't have most of the tools to do half them tests might have to suck it up and take it in
2005 mazda 6i 4spd atx
saint6 is offline   Reply With Quote
Old 11-09-2012, 03:19 AM   #13 (permalink)
trying to find a back pressure tester local just to rule out the converter if that's not bad i will look at changing the plugs and replacing the first o2 sensor.
Old 11-09-2012, 08:47 PM   #14 (permalink)
Groans: 42
Quoted: 4 Post(s)
If your cat is bad, you'll feel a noticeable "bite" immediately after shifts. I can't really explain it, but if you pull away gently from a stop, the engine RPM will build until the shift, right after the shift, you'll immediately feel a "bite" where the engine feels bogged down.
I dealt with a bad cat on my 04. I ended up replacing it with a Magnaflow high flow one.
If you aren't having those symptoms, chances are the cat is fine.
Old 11-10-2012, 10:34 PM   #15 (permalink)
i ordered the back pressure tester just to be sure i have the 05 6i atx with 2 converters has one built into the manifold and 1 right after the manifold with 3 o2 sensors.
i only get hard shifting from 1st to 2ed when the car is cold when its warmed up its fine planing on taking it in to see if there is a pcm/tcm update not sure its ever been done.
Old 11-11-2012, 12:24 AM   #16 (permalink)
recently added a can of the stp motor treatment think its like seafoam to the tank and filled up on 89 130 miles and no code has came back yet might take a little longer just did it to see what happens.
Old 11-11-2012, 01:23 AM   #17 (permalink)
Groans: 42
Quoted: 4 Post(s)
Ohhhh... Ok, I did not realize that you had a PZEV 6. I don't think the manual I posted above applies to those vehicles. That could be why I can find no trace of that CEL code that you listed. LOL.
