Cold Air intake question! - Page 5 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #41 of 52 (permalink) Old 11-06-2012, 12:53 AM
Slate6's Avatar
Quoted: 82 Post(s)
Groans: 5
Groaned at 36 Times in 26 Posts
Also did you put the air striaghtner in? if so, how did you put it in. It might be loose and shaking..
My Build Thread
Slate6 is offline
post #42 of 52 (permalink) Old 11-06-2012, 12:55 AM
Jordan6i's Avatar
Quoted: 36 Post(s)
There is no way he has it already lol...
Jordan6i is offline
post #43 of 52 (permalink) Old 11-06-2012, 12:59 AM
justsomeguy's Avatar
Quoted: 382 Post(s)
Wat these guys check for leaks specially map sensor seal/also would be a good time to clean it if u havent already.Other then that if the intake is 3" id without a cpe I bet that could be the cause like these guys already said too air straightener SHOULD fix it.
EDIT also u gotta look close at the maf seal a hairline crack is all it takes. Ive had one go one me and it boged out till i restarted the car.
I now keep two spares lol
Sent from Canada bitches at LTE quad core speeds on my upgraded kit Kat LG G2...mess with me I'll drive by and turn your tv off
justsomeguy is offline
post #44 of 52 (permalink) Old 11-07-2012, 08:25 PM Thread Starter
Knupsel's Avatar
Quoted: 751 Post(s)
Groaned at 8 Times in 8 Posts
Okay so i tightened my MAF down and it somewhat smoothed it out a little, the driving is smooth, but the idle still sounds a little rough to me!
I ordered the Straightener and i probably will take the intake out over the weekend until i get it in the mail.
Also this way i can check if the engine light is caused by the intake itself or if the little tube that attaches to the intake (not the big one that goes to the TB) is lose.
Knupsel is offline
post #45 of 52 (permalink) Old 11-10-2012, 07:50 PM Thread Starter
Knupsel's Avatar
Quoted: 751 Post(s)
Alright so did s quick swap back to the stock airbox and everything seems to be back to normal!
Smooth idle and all, so I think I'm gonna order the air straightener and wait till after winter with the intake!
Sent from my SGH-I747M using AutoGuide.Com Free App
Knupsel is offline
post #46 of 52 (permalink) Old 11-10-2012, 11:15 PM
Quoted: 400 Post(s)
Groans: 16
Groaned at 4 Times in 4 Posts
I have an air straightener I'll sell you on the cheap
tapatalking.. err wait.
xkreedx is offline
post #47 of 52 (permalink) Old 11-11-2012, 10:43 AM
Emew's Avatar
Quoted: 107 Post(s)
iTrader: 2 reviews
Surprised no one had mentioned it, it isn't required but did you disconnect your negative battery terminal for like 15 minutes? I did this and it smoothed out the idle and shifts started taking place at higher rpms after the first 50 or so miles. Also I being a picky person took it upon myself to remove the maf and put it in a ziplock bag full of isopropyl alcohol and shook it around for a minute or 2 then let it dry on a paper towel for a few hours. Helps make sure no small debris are throwing off your air flow readings. Cheap and quick potential solutions.
Sent from my dial up phone
Flow Tuned
Some car that has way too much money in MODs.
Emew is offline
post #48 of 52 (permalink) Old 11-11-2012, 11:25 AM
Slate6's Avatar
Quoted: 82 Post(s)
Groans: 5
you put your MAF in liquid......your brave
My Build Thread
Slate6 is offline
post #49 of 52 (permalink) Old 11-11-2012, 02:32 PM
Emew's Avatar
Quoted: 107 Post(s)
iTrader: 2 reviews
Isopropyl alcohol drys different from other liquids especially when it comes to electronics. dip a q tip in some and wipe it on a table, see how long before it evaporates. I never had a cel from my maf even after it was soaking in a bag of it for an hour. The higher the percentage the safer it is for this purpose though, I'd stay at or above 85%
Flow Tuned
Emew is offline
post #50 of 52 (permalink) Old 11-11-2012, 02:42 PM
Slate6's Avatar
Quoted: 82 Post(s)
Groans: 5
Good info
Sent from my SGH-T679 using AutoGuide.Com Free App
My Build Thread
Slate6 is offline
